Crank sensor loose maybe?
Old Mar 28, 2011 | 02:26 PM
donjulio's Avatar
donjulio
I replaced the oring.
After I fit in the oring and tightened the bolt, I can feel maybe 1/3 of a fingernails width between the sensor and the engine. I turned on the engine and Its not leaking now... Should I be worried? Is the new oring too fat? mm
Old Mar 28, 2011 | 03:07 PM
HRM's Avatar
HRM
If it is torqued properly and not leaking you are good to go. Check once and a while to make sure.. I can't say how they are normally.
Old Mar 28, 2011 | 06:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Did you lube the Oring before installing? If not it may not let you slide it in. I suggest pulling it out and reinstall it.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
sempaipaul
Sep 18, 2015 03:05 PM
Norton70
Sep 7, 2015 05:06 PM
M7Speed
Sep 3, 2015 07:48 AM
