inpa question
Old Oct 13, 2019 | 04:48 PM
ssoliman's Avatar
ssoliman
inpa question
Hi all, quick question regarding inpa, if i may.
i have inpa installed on a laptop but it connects to the engine module only. Feel like I'm missing something obvious.
What version of inpa works best with mini's (R53, 2005 MCS)?
What cable should i be using if different from the one that i have (pic attached)?
Old Oct 14, 2019 | 09:11 AM
adriancl's Avatar
adriancl
Check if have shortcut between pin 7 and 8 on INPA.If not, must do it.
Old Oct 14, 2019 | 05:25 PM
ssoliman's Avatar
ssoliman
Thank you for the reply, adriancl
can you expand on that. Pin 7 and 8 where?
Old Oct 14, 2019 | 09:24 PM
adriancl's Avatar
adriancl
https://images.app.goo.gl/SAhuqcPaMj9ZuL7s9
Old Oct 15, 2019 | 09:55 AM
ssoliman's Avatar
ssoliman
Gold sir, thank you
maybe I can find one already jumped for sale
i will report back
Old Oct 15, 2019 | 10:16 AM
RB-MINI's Avatar
RB-MINI
Is there a switch on the other side of your cable? Some of those cables have one built in to jump pins 7&8 when needed.
Old Oct 15, 2019 | 10:43 AM
adriancl's Avatar
adriancl
Better with switch , because can do diagnosis also on CAN line for instruments culuster.
Old Oct 15, 2019 | 08:37 PM
ssoliman's Avatar
ssoliman
Thank you, gents. Found this one on amazon:
Amazon Amazon
What version of inpa are you guys running or does it not matter much?
Old Nov 3, 2019 | 02:40 PM
ssoliman's Avatar
ssoliman
Tried the inpa cable linked above and it does not seem to work at all.
The original cable that I bought will connect to the engine module, nothing else.
The new cable has a switch on it with 4 positions. Tried all four separately, closing inpa and re-opening each time. With the ignition on (second position just before start) in all four positions the ignition shows off (not connected).
Put in the original cable that I have, in the same USB port, close inpa and reopen and it’s connected.
Some backround...the install of inpa is one I did from a bmw forum to work with older (1999) bmw’s.
I’m at a stand still on this. Any advise is much appreciated.
Maybe I need to start over with a different laptop? Runing inpa for a mini and bmw might be wishful thinking?
Beau M
Aug 22, 2012 10:41 AM
Acesup1090
Oct 25, 2010 09:25 PM
andersona8
18
Jan 31, 2004 08:55 PM
