Oil filter house gasket AGAIN!!!
Old Oct 6, 2019 | 03:24 PM
jjcsnlynn's Avatar
jjcsnlynn
Ok, I have changed the oil filter housing twice now and both times it started to leak with one tank of gas later.
I can’t understand why. First time I didn’t torque the bolts just made them tight. This time torqued them to 100 inch pounds. First time I changed the cooler gaskets but not this time.
What di I need to do to stop this leak? I saw where one person rtv’d the housing on but I don’t want to do that.
What else can I do?
Old Oct 7, 2019 | 06:02 AM
MiniToBe's Avatar
MiniToBe
according to newtis.info, it should be 10Nm, about 88.5 inch pound.
Old Oct 7, 2019 | 08:50 AM
jjcsnlynn's Avatar
jjcsnlynn
I know it’s 88 in lbs but I did a lot of reading on this forum and it was suggested to go 95-100 inch pounds.
Are you saying that if in make the less tight it will seal longer?
I don’t understand that philosophy.
Old Oct 7, 2019 | 08:55 AM
MiniToBe's Avatar
MiniToBe
what I'm saying is that this is what the spec calls for. I've done it few times per spec and had no issues. since you tried the over torquing method and it failed, you're only left with just regular torquing and new gasket. I agree with you on the RTV. I'm not a fan of it either.
CSP
Aug 6, 2018 02:28 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
one73ronin
15
May 24, 2015 09:13 PM
fenderpicks
Nov 4, 2014 03:47 PM
Dizzy_Jenny
17
Oct 17, 2007 08:02 AM
