Anyone replaced the AC expansion valve on an R56 Cooper?
Old Jul 2, 2019 | 02:58 PM
  #26
mkov608's Avatar
mkov608
Well, I messed that one all up! I replaced the flap servo motor never suspecting it was the temp control rheostat causing the problem. What a PITA!!! I had to take the dash apart to replace that motor.
So I have to replace the temp control rheostat next, and that's the whole AC panel. You can find used ones all over Ebay, but you're never sure if they are going to make the problem worse.
Old Jul 2, 2019 | 03:08 PM
  #27
Lex2008's Avatar
Lex2008
I though you said the motor wasn't closing the flap all the way?
Do you have to take the dashboard off to change the servo or just the center console? I need to change the radio display anyway so Im gonna do it all at once.
You mean you should have changed temp control rheostat = B11b in the pic below?:
Old Jul 2, 2019 | 03:22 PM
  #28
mkov608's Avatar
mkov608
Right, the motor wasn't closing the door all the way, but the temp control **** (rheostat) tells the motor what to do.
That looks like the left side view of the plenum. The temp control door servo motor is on the right side between the center console and the glovebox. You have to pull the whole dash apart to get to the stupid servo motor.
I have to change this:
Old Jul 3, 2019 | 06:37 AM
  #29
Lex2008's Avatar
Lex2008
oh so the temp control **** was the cause of your problem. Thats good to know! That could be my issue as well.
I assume the only way to test it is to take it apart and check resistance. By the time youve taken it all apart you might as well just swap it out along with the servo motor and temp sensor....
Old Jul 3, 2019 | 08:24 AM
  #30
mkov608's Avatar
mkov608
Right ... reference the video I uploaded.
I wouldn't bother trying to take it apart because you probably won't be able to fix it. To test it, check out the video again.
Old Jul 3, 2019 | 09:27 AM
  #31
techman1's Avatar
techman1
Lex,
Did you say your HVAC is the autotemp?
I am not sure, but does mkov608 have auto temp also?
Looks manual. Maybe that is the flapper difference.
Old Jul 3, 2019 | 09:33 AM
  #32
Lex2008's Avatar
Lex2008
Techman1,
Yes it has the automatic climate control. Mine looks nothing like mkov608's.
I just need to know how to test the flapper door vs the rheostat so I know what to change.
Its getting hot and I just spent $700 installing a new AC system!
Old Jul 3, 2019 | 10:58 AM
  #33
techman1's Avatar
techman1
After a good bit of looking, even on realoem, I could not find the location of the automatic blend door on our car.
I am thinking it is near the passenger footwell behind the panel on the left. I will check when I get home.
Old Jul 4, 2019 | 09:17 AM
  #34
mkov608's Avatar
mkov608
Lex, check this out!
https://www.northamericanmotoring.co...mp-solved.html
Old Jul 4, 2019 | 09:36 AM
  #35
Lex2008's Avatar
Lex2008
Originally Posted by mkov608
Ok cool! Thx.
Old Jul 14, 2019 | 07:13 PM
  #36
Lex2008's Avatar
Lex2008
MKOV,
I bought a better boroscope and recorded the door to the AC evaporator being blocked off for heat and then when visible, its open to air flow from the blower. It looks like its closing all the way, but Im not sure. This is while accessing from the vent on the left of the speedo. Again my car has automatic HVAC.
Old Jul 29, 2022 | 04:52 PM
  #37
Lakotamani's Avatar
Lakotamani
What happppeeennneeeedddd???!!!!
Old Jul 29, 2022 | 05:23 PM
  #38
Lex2008's Avatar
Lex2008
With what?
c0op3r
Jan 29, 2014 02:26 PM
JAB 67
Sep 16, 2013 04:22 AM
bkjnf
Aug 4, 2013 07:52 AM
rzermani
Jul 14, 2012 12:53 PM
dominicminicoopers
May 14, 2004 09:47 AM
