Limp Mode when hitting bumps? Electrical issue?
Old May 3, 2019 | 07:26 PM
Fische18's Avatar
Fische18
I have a 2005 S and while driving to work yeh other day my EML and Check Engine lights came on when I hit a bump and again further down the road when I hit a bump. It was a cool damp Maine morning. Problem only really occurs when I hit bumps or sometimes when I accelerate quickly. It always seems to reset itself so I don’t have any codes.
The clock always resets when the problem occurs like a better connection, but those are tight.
Any help or advice would be appreciated. Even which electrical connectors I may need to check.
Old May 4, 2019 | 02:44 AM
knt's Avatar
knt
Try checking and cleaning the battery terminals for rust and then tightened properly.
Might be worth checking the ground terminal to see if it's secure and in good condition.
Old May 4, 2019 | 08:17 AM
Jim Willittes's Avatar
Jim Willittes
Fix??
Hi Fische18, did you ever get this issues fixed?? I have a 2006 MCS with similar issues, thx
Old May 4, 2019 | 04:43 PM
Fische18's Avatar
Fische18
no, I have not gotten a chance but plan to look at it tomorrow
Old May 11, 2019 | 07:12 AM
Fische18's Avatar
Fische18
Well, I didn’t get far before I found an issue. Started in the battery compartment and found that the BPS wire was cut, the cable from the battery to the fuse terminal was slightly cut and there was a lot of rust. The battery hold down was also close the the positive terminal. I ordered some new parts and hope the problem gets fixed.
Is there an issue with the BPS wire being cut?
danEdmonds
Mar 16, 2013 02:05 PM
adr3naline fix
Mar 3, 2013 10:54 AM
SNEEEZY - Erika
Suspension
Nov 9, 2008 05:38 AM
MrsTune
Apr 24, 2007 03:43 PM
Scott4399
Tires, Wheels, & Brakes
Jan 7, 2006 10:59 AM
