Coolant Thermostat Adapter Lead placement
Old Feb 17, 2019 | 07:15 AM
OldElvis's Avatar
OldElvis
So I have just completed the Thermostat replacement on my 2011. I find out that I need the Coolant Thermostat Adapter Lead cable. Problem is , no explanation on where the other end goes. Any Guidance here? Looking on the posts on the replacement, no instruction on the cable part.
Thanks in advance,
Dennnis
Old Feb 18, 2019 | 05:36 AM
MiniToBe's Avatar
MiniToBe
I use this harness https://www.ebay.com/itm/Genuine-Min...wAAOSwMVdYIimH
it is 1-2 harness. one end has 4 wires and they go to the main plug. the other two 2-wire plugs go to the thermostat and the other to the temp sensor.
Old Feb 18, 2019 | 05:41 AM
OldElvis's Avatar
OldElvis
What I wound up doing ( and So Far it appears to be functioning fine) was to take the original sensor plugs, and remove the external clips ( which lock it into the sensor) and plug the rest into the 4 port plug on the Coolant adapter directly. This harness looks the same.
Boosted_Mini
How to
235
Aug 7, 2023 11:01 AM
tkenupp
Jan 31, 2018 07:41 AM
njdangler13
Jun 28, 2016 07:02 AM
wrnchhd
Nov 25, 2015 01:26 PM
jhiggs26
Oct 17, 2013 05:26 PM
