High fuel pressure at idle
Old Jan 31, 2019 | 12:54 PM
RCRacer's Avatar
RCRacer
2013 1.6 turbo. I'm seeing 1,000 psi at the fuel rail according to the Torque app at about 700 rpm. I see 1,700 + at higher engine speeds.
I'm on the verge of getting a system rich code as the fuel correction exceeds -20 at times. This would seem to be a regulator issue, but I can't find any info on a regulator.
Is it built into the HPFP? I realize I could have a leaky injector but the pressure seems high by a couple hundred psi..
Old Jan 31, 2019 | 06:05 PM
MrGrumpy's Avatar
MrGrumpy
It doesn’t really sound too high iirc where mine usually sits at idle. I haven’t actually looked for a while. But it sounds like it’s in the right range.
That said, don’t listen to me! Ha ha
like I said I haven’t actually looked for a while and my memory is far from perfect. Someone else will be along to get another opinion from sooner or later.
MiniCooper_S
Feb 17, 2023 07:47 AM
ozmusafir
Dec 9, 2022 01:27 AM
SirNelson
Aug 1, 2014 12:27 PM
Headlands
R55 :: Clubman Talk (2008+)
Apr 2, 2010 02:23 PM
mrmagoo
Aug 7, 2009 07:02 PM
