Car not starting! Turns over but won't fire! Please help!
Old Jan 28, 2019 | 04:58 AM
kayer56's Avatar
kayer56
Hello,
i have a 2008 mini cooper s r56. yesterday morning i started the car to warm up because its winter and its cold outside. I had to turn off the car and then when i came back a few seconds later to start the car, it wouldn't start. it turns over but it just wont fire! no warning lights!
battery is brand new, full tank of gas, spark plugs are still good and changed one coil. and still nothing.
thank you
kaye
Old Jan 28, 2019 | 08:57 AM
MiniToBe's Avatar
MiniToBe
check relays and fuses. also check the ground wire on the valve cover. get an obd reading even if there are no codes.
Old Feb 7, 2019 | 10:42 AM
Ronnie's Avatar
Ronnie
Did you ever find the problem? Could be fuel pump. I had the same issue and had to change my fuel pump.
Old Feb 7, 2019 | 02:24 PM
kayer56's Avatar
kayer56
Turns out it was the timing chain! The guide broke, the common mini cooper curse.
09R56
Nov 16, 2022 10:49 AM
clubman2009
Aug 8, 2018 09:41 AM
NeonLed
Nov 27, 2017 10:58 PM
Amos 08
Oct 19, 2015 11:29 AM
SFarbolin
Dec 7, 2014 09:52 PM
