Just a skosh of steering play (u-joint)
Old Dec 17, 2018 | 03:50 PM
bdubya's Avatar
bdubya
I've been bothered for a couple of months by a tiny bit of play in my steering....just a few degrees (like maybe five or ten) of looseness before I get feedback and response. Not a big deal, just annoying because it doesn't feel like it used to. Since I already had it up on stands for a few reasons (brake master & check for leaks, plus ABS sensor) this was a good time to trace it down, and it's definitely just a little bit of play in the lower u-joint in the column. The rack itself is tight, no play at the rod ends, everything's tight except that lower u-joint. So I'm wondering if anybody knows any tricks for tightening that joint up? It's not a big enough issue to justify a brand new lower column (and a salvaged one might be no better and could be worse), but if anybody has a magic trick to share, it's definitely worth the minor trouble of pulling the shaft out while the car is up. Otherwise I'll just live with it.
Old Dec 25, 2018 | 02:28 PM
BruceJ's Avatar
BruceJ
Right hand side, Is this what you are talking about? if so REALOEM doesn't break the part down any further than the lower column, probably about $250 shipped. BUT.. at the lower end this is a old school needle bearing U-joint. If you can get it out and have a set of calipers you can probably spec it well enough to find a replacement.. But Ive never heard of these developing slop. You typically find them in driveshafts and they need to hold up there. Makes me think that maybe the problem isn't the U-joint, but lower where the clamp attaches to the steering rack. Per RealOEM there is a torx bolt there, maybe its just as simple as it came loose and needs to be tightened..
Good Luck
Bruce
Old May 22, 2019 | 12:28 PM
bdubya's Avatar
bdubya
Just to follow up...closer examination showed the u-joint to be tight. Tried a little extra torque on the pinch bolt...no help. Then, a couple of weeks ago, my steering effort started varying - very light, then heavier, all kind of randomly, and the on-center play started to come and go as well. Finally, yesterday I pulled the pump out, opened it up, blew the motor out with an air compressor, hosed everything down with brake cleaner (a lot of dust blew out, and a lot more came out with the brake cleaner), put it back in, and refilled with fresh Pentosin CHF-11S. That fixed everything - the steering is tight on-center, and the effort is consistent. Don't know if it was the fresh fluid, the clean motor windings and such, or a combination of the two, but it made a huge difference for the price of a little labor and a can of Pentosin.
JoeyF
Aug 16, 2023 04:45 AM
cabbazio311
Apr 11, 2012 08:24 AM
Some Guy
Dec 29, 2011 03:17 PM
fatbas
Jun 4, 2009 12:48 PM
r56mini
Aug 23, 2007 07:58 PM
