instrument cluster dead along with alot of other things!!!!!!!
Old 11-28-2018, 01:35 PM
Matthew Miller's Avatar
Matthew Miller
Matthew Miller is offline
hello my girl friends mini is an 07 cooper s the car sat for a month and was dead she jumped it and now alot of the dash is dead.
here is a list of all that is dead!!!
the center of the tach is flashing service, abs, airbag, and gas.
the break,!,abs,airbag,and engine lights are on.
the tach - speedo - gas gauge - heater/ac fan - wipers - heated seats
the reverse light will not light in reverse.
also the car will not lock /unlock
and when the car is parked and off. the p for park near the shifter is staying lit and the center of the tach flashes the service and will not turn off.
please help with any ideas on how to fix this!
Old 11-28-2018, 01:54 PM
DneprDave's Avatar
DneprDave
DneprDave is offline
Make sure the battery is good. MINIs do a lot of weird electrical things when they have even a marginal battery. How old is the battery, it may be time to replace it.
It was not a good idea to jump a dead battery, that could have killed the body control module. The best way is to put a charger on the battery and make sure it has a full charge, before trying to start it. I would try a new battery first, if that doesn't work, then try a new Body Control Module.
Matthew Miller (11-28-2018)
Old 11-28-2018, 02:07 PM
Matthew Miller
the battery is less than a year old. we also cheked all the fuses and their all good.
Old 11-28-2018, 03:50 PM
DneprDave's Avatar
DneprDave
Bring it to an independent MINI shop and have them scan it with their MINI/BMW specific scan tool, I'd bet the Body Control Module is fried. This is a classic scenario, jumping the car with a dead battery will do it. Was there a spark at the battery terminal when you connected the jumper cables to the battery? That's when it happened.
Here is a site that lists MINI specialists nationwide.
https://www.minirepairshops.com/
You could Google, 2007 mini body control module, and you will find all kinds of discussions here at NAM and elsewhere.
Old 11-30-2018, 09:19 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
BCM (aka foot well module) is my guess but if it was all exposed to water there could be even more damage. Did the sunroof ever leak water? Was there a pool of water on the front floor? If the battery holds the charge and is good that the next thing i would check.
Old 11-30-2018, 03:53 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Fuse box behind the passenger kick panel.
Where are you located?
Micromachines
R55 :: Clubman Talk (2008+)
12-29-2015 01:40 PM
-=Mike=-
08-14-2012 11:26 AM
ZAKdog
12-03-2003 04:00 PM
dave
Off-Topic :: Autos
11-05-2003 06:32 PM
Carroll
01-04-2003 10:27 AM
Quick Reply: instrument cluster dead along with alot of other things!!!!!!!
