Boost leak
Old Sep 23, 2018 | 01:05 PM
Ricbri69's Avatar
Ricbri69
Boost leak
I'm running out of ideas on this one, so I'm throwing it out to the group for help. A few months ago, I picked up an 03s with 130k on the clock. Po bought it with a bad head gasket, had his friend (a BMW mechanic) repair that, also found supercharger was shot. Sent it to Dustin at stateline for a rebuild, slapped it in with a 15% pulley, just started driving it and found out he had stage 4 cancer. I picked it up from him in June and have been driving it since.
Aside from the pulley its stock. I decided to add a boost gauge and I'm only seeing a max of 10psi, and it starts around 6psi ar lower rpms. With the pulley, I understand I should be up near 15 psi or so?
so in my quest to correct it, I've done the following:
-checked pulley isn't slipping on sc shaft, replaced belt
-checked bpv function with vac gauge, adjusted set screw so it closes pretty well
-pressure checked from throttle body to head. Looks tight, changed out a bunch of gaskets that were leaky or questionable(intake mani, mani horn to ic, ic boots, injector o rings, throttle body gasket, sc inlet)
-tried vgs mod to see if it helped. No real improvement.
at this point, I'm about out of ideas. Last few thoughts:
-supercharger not producing enough boost (but Dustin seems like the go to guy for rebuilds)
-bpv leaking back into intake tract (looks like it seals ok visually, but I dont know how tight it should seal?)
-withcraft or bad juju from rocking Japanese cars my entire life until now.
any ideas? She runs good, but I feel like I should be getting more from it and its driving me nuts! Thanks all!
Old Oct 11, 2018 | 06:44 PM
Ricbri69's Avatar
Ricbri69
Guys, since the last post I have changed out the crank pulley as it was looking pretty tattered and I feared it might be failing, however that didnt fix it. Still cant get beyond ~10psi.
I'm losing my mind here. My last few guesses, which I really dont want to just shotgun because I'm tired of spending money:
-bpv leaking by, even though it looks and behaves correctly
-belt slip due to tensioner issue? Not sure how to test this
-bad supercharger rebuild, which again seems unlikely
anyone have any thoughts at all? I know this car can do more and its killing me not knowing what's wrong...
thanks!!
Old Oct 12, 2018 | 05:59 AM
Tgriffithjr's Avatar
Tgriffithjr
How does it run on the road?
Old Oct 12, 2018 | 06:24 AM
Ricbri69's Avatar
Ricbri69
it runs very good. Having not driven this car before the repairs or another r53 in good shape, I cant say how it compares as far as power. Boost hits quick and hard, no codes, no stuttering, it runs good, just feels like it should be a bit stronger in boost, and the 10psi max kinda agrees with that. Would love to put it side by side with a good running r53 either stock or with just a pulley for comparison, but I dont know anyone local with one. Northeast PA isnt exactly brimming with them...
thanks!
Old Oct 12, 2018 | 07:08 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've seen improper rebuilt superchargers only make 10psi before. So I would be checking that.
Old Oct 12, 2018 | 07:18 AM
Tgriffithjr
Did you connect into the pressure regulator line under the intercooler? Or the intake manifold?
Old Oct 12, 2018 | 07:30 AM
Ricbri69's Avatar
Ricbri69
I teed in at the intake mani, although that is tied to the fpr line also. Also verified boost gauge using torquelite and my obd2 scanner - boost from the app shows within 0.5 psi of the gauge at all times.
Old Oct 12, 2018 | 08:00 AM
Ricbri69's Avatar
Ricbri69
Thanks Way - any idea how to test that? I'm going to call the rebuilder later and talk it over with him as well.
DRoc7822
Feb 15, 2016 12:47 PM
SooperCuperErik
Dec 16, 2011 11:58 AM
Marwan
Apr 23, 2011 08:29 AM
ortuna
May 23, 2010 10:33 PM
Mr. Incredible
Mar 20, 2009 11:22 AM
