ABS ASC and Low tire light turns one, please help!!!
Old Sep 19, 2018 | 01:27 PM
R53hyperblue's Avatar
R53hyperblue
I have a problem with my R53 2006, the ASC, ABS and low tire turns ON almost all the times I use the R53, I know mostly sure is a wheel speed/ABS sensor problem, here in Mexico almost all the scanners arent compatible with the R53 (something with the OB2), some scanner gave me a code for a rear wheel speed sensor, the one of the left, I bought a generic sensor but the same problem the lights of the ABS, ASC and low tire came on in the DASH, so I bought 2 rear OEM sensors but preowned at eBay, I changed both, right and left, but again the lights in the Dash turned on, what do u think is happen ? didnt have luck with the sensors the I bought (generic and preowned) ? or could be something else ?, any experience in this ?
I really want to solve this to dont have any light/code in my R53 Dash, pelase help!!!!!
Thank you so much in advance!!!
Old Sep 20, 2018 | 06:45 PM
gpskipton's Avatar
gpskipton
ODB Reader
I had the same issue and bought the V7.9 Creator C310 Plus C310+ Code Scanner for BMW Mini Multi System Scan Tool on Amazon. Pretty cheap and pulls the ABS codes (and SRS and many others). It told me which wheel. It also told me my passenger seat sensor is throwing the SRS light.
Old Oct 4, 2018 | 04:45 PM
R53hyperblue
I hope u want to sell it to me hehehe =)
Did u use it in a R53 ?
Old Oct 4, 2018 | 05:25 PM
gpskipton's Avatar
gpskipton
Yes... I used it on my 2006 R53
It reads the sensors just fine. It should tell you which wheel. I also picked up on the steering angle unlike what the other poster said. You can drive and pick up live data.
j-gregs
Jul 12, 2020 06:02 AM
Mike Austin
Apr 22, 2010 10:47 AM
adrianr
Jun 13, 2009 05:49 PM
robertsmau
Sep 6, 2007 01:03 PM
