some sort of reset?
Old Sep 10, 2018 | 12:41 PM
Phorine's Avatar
Phorine
some sort of reset?
Is there any sort of voltage safety shutdown/reset that would cause the dash to light like a Christmas tree and then reset and come back up? Also, the more annoying part is that ps seems to do the same.
This started around the time I lost my alternator (and then went thru 3 shitty auto parts store rebuilds to get one that works). I think I was getting too much voltage out of the second alternator as it would rev up. I think it hit 16.7v or something according to my scanner. I can’t remember. Either way, it seems like the dash/power steering, etc would all reset when I hit like 4K on the tach. It’s been fine after I swapped the alternator and I thought it went away, but I’ve had the same issue pop up the past couple of days, but now it only seems to pop up over 5k. I’ll go read the codes and see if it popped anything, but it didn’t last time. I didn’t think of it until now because My car usually has the cel lit due to the high flow cat and full exhaust the po installed.
Old Sep 10, 2018 | 12:58 PM
Phorine's Avatar
Phorine
Ok, I checked the codes. I had some downstream o2 sensor nonsense, which I always have, but it did throw speed sensor a as well. I reset them and tried Monitoring the voltage as I rev the engine. The max I got thru the scanner was 16.5, and it was cutting out/Christmas treeing consistently about 5500 rpm. Any ideas?
Old Sep 14, 2018 | 08:31 PM
Black Forest's Avatar
Black Forest
Your alternator put out 16.5V? Wow that’s way too high.
Old Sep 15, 2018 | 02:08 AM
DamnCampers's Avatar
DamnCampers
It has all the sounds of a bad voltage regulator for the alternator. Only thing that leads me to this is that I had an 84 Toyota truck that had a seperate regulator. It up and died one day and it gave all the symptoms of a bad alternator. Every new/reman alternator put in it would die within days. After discoverying the regulator was seperate from the alternator, it was fixed by replacing the voltage regulator.
Old Sep 15, 2018 | 02:09 AM
DamnCampers
Here is some more information on it from one of the vendors here on the forums https://www.pelicanparts.com/techart...eplacement.htm
vietnameeh
NorCal MINIs
Apr 29, 2013 09:55 AM
-=gRaY rAvEn=-
Tires, Wheels, & Brakes
18
Mar 26, 2012 06:38 PM
kenros
Feb 10, 2008 10:43 AM
omnivector
Dec 23, 2007 01:33 PM
