I need help identifying a front passenger side noise
Old Aug 22, 2018 | 02:51 PM
Ronstang's Avatar
Ronstang
I have had this car only for a couple hundred miles but it's been sitting since I bought it because it needed lots of little work that I am now doing, the car has 75K miles. My concern is the noise that comes from the passenger side. It's a clank I guess. Kind of sounds metallic, reminds me of a race car with a heim joint clunking over a bump. I can hear this noise just backing out of the garage and coming off the little inch and a half bump, or going into or out of the driveway....so it happens at very low speeds.
I have already put new struts all the way around, replaced the front strut mounts and fixed the ballooning shock towers. The noise is still there. The tires are bald and old so harsher than normal. I have new rims and tires that will go on as soon as the car is driveable again but I don't think that will make much difference.
The hydraulic motor mount is completely shot, a new one is on order but I don't know if that could be part of the problem or not.
I have checked the front suspension but can't find any looseness or severely worn parts. If anyone can suggest a good way to check these parts that would be much appreciated. The suspension is so tight that I can't seem to make it move at all . I don't know if I need to separate the lower ball joint and deal the the lower control arms by themselves to see if I can find any bad ball joints or bushings.
I want to take this car to Atlanta three weeks from tomorrow so I don't want to do elective work, just what is needed.
Any help or advice would be greatly appreciated. I have to go to chuch in an hour and will be unavailable until 9 pm central standard but will answer any questions anyone might have ASAP.
Thank you in advance. I've been part of many forums for Mustangs and everyone is always eager to help. I can't see it being any different for Minis!!!
Old Aug 23, 2018 | 07:58 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Thread was moderated - approved it, and moved to Gen1 Stock Problems/Issues where you should get some help. You didn't say explicitly but I'm guessing Gen1 from some of the issues you described.
Old Aug 24, 2018 | 07:23 AM
Ronstang's Avatar
Ronstang
Yes, thank you. Its a 2005 Mini Cooper S. I have the whole front end off and am resealing the engine and doing preventative maintenance and a quick restoration so it's the perfect time to fix as much as I can.
Old Aug 24, 2018 | 07:34 AM
Subw00er's Avatar
Subw00er
There is a youtube mini cooper video that shows how to kick and push the tire to identify which mounts are bad. Its probably going to be the inner or outer ball joint or arm mount. I suppose it could also be worn sway bar mounts. Also, check the tightness of the sway bar end links, if they are not tight, it will make this clank and it seems to be a fairly common issue.. You can fit a wrench behind the mounting point on a couple flat spots to hold the bolt while tightening the nut., or use the allen wrench, wrench method.
Old Aug 24, 2018 | 07:39 AM
Ronstang's Avatar
Ronstang
Thank you I will follow your instruction as soon as I get out I the garage today. Much appreciated
Old Aug 24, 2018 | 06:02 PM
Subw00er's Avatar
Subw00er
I cant find the video now.. but basically you kick the tire treads, then wiggle left to right from the rim side, then top to bottom.
Old Aug 24, 2018 | 07:43 PM
Zsm's Avatar
Zsm
Since you already replaced the struts, it could be ball joints, control arm bushings or sway bar end links.
End links are inexpensive and easy to replace. It was the source of a lot noise on my kid’s car. If you’re not the dropping subframe, then just do that first. If you do plan to drop the subframe, then do it all.
Old Sep 7, 2018 | 12:55 AM
Ronstang's Avatar
Ronstang
I replaced the control arm bushings with ones from PowerFlex, I also went ahead and replaced the sway bar bushings and both inner ball joints while I was in there so everything attached to the sub-frame is new. When I finally get this car on the road again if the noise is still present it can only be outer ball joint or sway bar end link, which are both easy to get to with the car completely assembled.
Old Sep 8, 2018 | 01:25 PM
ItsmeWayne's Avatar
ItsmeWayne
It may well be bad motor mounts
Old Sep 8, 2018 | 02:07 PM
Ronstang's Avatar
Ronstang
I just replaced the hydraulic motor mount, others looked fine. Can't drive the car yet but I'll know for sure if the noise is gone this week.
bansasn
Jul 6, 2017 01:44 PM
pkx
Nov 22, 2014 05:40 PM
2003minicooper
Suspension
Apr 9, 2013 05:02 PM
keverline
Apr 25, 2010 06:33 PM
at7815
Aug 11, 2007 02:06 PM
