Rear knocking noise when braking Mini R50
Old Aug 6, 2018 | 03:43 PM
user 73920's Avatar
user 73920
I started hearing a "knocking" sound coming from the rear right of the car ONLY when I put on the brakes...any ideas on what might be the source of this problem? Everything on my rear axle,brakes, shock absorber, rods, bushes ect are new (4k km in total)
Old Aug 7, 2018 | 07:40 AM
cooper48's Avatar
cooper48
Rear knocking problem
Most common issue with this type of sound is either worn out rear sway bar bushings and/or sway bar end links.
Old Aug 7, 2018 | 07:56 AM
user 73920's Avatar
user 73920
The sway bar bushings and sway bar end links are new :-(
Old Aug 7, 2018 | 09:05 AM
downshift1's Avatar
downshift1
It sounds like "pad knock" the tabs on the pads (guessing aftermarket pads?" are smaller than the originals or the hardware (stainless steel pad guides) wasn't replaced when the pads were put in.
Old Aug 7, 2018 | 09:13 AM
user 73920's Avatar
user 73920
Yeah the pad are aftermarket by Bosh, the anti whistle its still present, the pad guides are absent but it's normal, the etk can confirm this
Old Aug 7, 2018 | 09:19 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Unless I'm mistaken, there are no pad guides on the Gen 1 MINI brakes...
I also have this phenomenon after recently changing my brakes all around (Akebono pads/Zimmerman rotors).
All suspension components, front and rear, have been recently replaced.
Old Aug 7, 2018 | 10:01 AM
downshift1's Avatar
downshift1
Sorry to confuse, just listing off the usual suspects.
Can you wiggle the pads forward and backwards against the slides once everything is together? If so there's your noise.
Old Aug 7, 2018 | 10:19 AM
user 73920's Avatar
user 73920
My pads are secure in place, no movements at all
Old Aug 7, 2018 | 12:55 PM
downshift1's Avatar
downshift1
Hmm interesting, do the caliper bushings feel nice and tight?
Old Aug 7, 2018 | 01:12 PM
user 73920's Avatar
user 73920
Nice and tight :-( no movement nothing, anyway the pins on the right side are shiny and clean (according to the workshop manual, the lubrification for the pins is prohibit)
Jul 27, 2012 05:38 PM
apblndp1
Nov 29, 2011 06:00 PM
rickyr53
Dec 16, 2010 10:21 PM
projekt7
Apr 6, 2009 12:02 PM
mataku
15
Dec 6, 2004 09:34 PM
