R53 Oil Pressure Issue
Old Jul 18, 2018 | 11:14 AM
  #26
enlyghten's Avatar
enlyghten
So, day 2 and the car is still operating correctly.
I purchased a Craven Speed oil pressure adapter
An Auto Meter Pro Com Ultralight oil pressure gauge
https://www.autometer.com/2-5-8-oil-...mech-4204.html
And some steel braided hose to replace the nylon that comes with the gauge.
The only thing I need now is a mounting option. Most of the mounts I've found are for without the chrono pack. The only thing I've found for the chrono pack is where someone used Velcro to mount their gauge, which I'd prefer not to do. Anyone have any leads on a chrono pack gauge mount?
I found a photo of a chrono pack gauge mount for Minimania, but it has a bad link and I can't find a chrono pack mount on their website.
I bought the 66mm gauge and apparently almost nobody sells cups for that size. I may have to return it and buy the 60mm (Correction - 52mm) version.
*UPDATE*
I did find a mount that said it would work with chrono pack version.... $47...
https://www.minicarparts.net/Parts/M4301L
And this, I guess, but it uses a sheet metal screw to screw into the plastic rear cover of the tach/speedo... Not ideal.
https://www.carid.com/alta-performan...86700#features
Old Jul 18, 2018 | 07:26 PM
  #27
minsanity's Avatar
minsanity
Why not on the A Pillar?
http://ortizcustompods.com/mini.html
Old Jul 18, 2018 | 07:29 PM
  #28
enlyghten's Avatar
enlyghten
That is nice, but 4 weeks to ship...
Old Jul 18, 2018 | 08:22 PM
  #29
minsanity's Avatar
minsanity
Not worth the wait?
Old Jul 18, 2018 | 08:27 PM
  #30
enlyghten's Avatar
enlyghten
Might well be, but the whole reason I'm installing the gauge is because I can't trust my stock gauges. I really need it installed in the next couple days unless I want to keep driving around with the tester attached or leave it garaged for the next month. I'd probably grab it if time weren't a factor.
I appreciate the suggestion- you must have some internet-fu -- I've been looking for something like that for the better part of a week now.
Old Jul 18, 2018 | 09:03 PM
  #31
minsanity's Avatar
minsanity
Do some temporary mounting(zipties, duct tape :D) while waiting. If we must, might as well make em look worthy & clean. Hehe.
MINI mods don't really need much searching. Everything is out there.
Old Jul 19, 2018 | 06:03 AM
  #32
enlyghten's Avatar
enlyghten
-_- Clearly true, but you don't have to rub it in =P I'll consider it. Do you know how easy it would be to route a steel braided line for a mechanical gauge with that mount? There's no details on the website.
Old Jul 19, 2018 | 07:07 AM
  #33
minsanity's Avatar
minsanity
Never intended to rub anything in, sir.
You can even DIY it like @Blaxin41 here...
https://www.northamericanmotoring.co...d-project.html
Old Jul 19, 2018 | 07:32 AM
  #34
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I would not replace the high quality nylon line included with the Autometer with unknown quality steel braided one. The extra mass also tends to cause material fatigue from broadband vibration. There is more than what meet the eyes, and more complexity is seldom better. I have written in depth in my thread.
Old Jul 19, 2018 | 08:16 AM
  #35
enlyghten's Avatar
enlyghten
One person says use the nylon. Another says don't use nylon. My thought process was to use something engineered for higher temp and pressure without the problem of kink damage like copper lines. Without personal experience one way or the other, how does one decide who to follow in cases like this?
Old Jul 19, 2018 | 02:45 PM
  #36
minsanity's Avatar
minsanity
Not sure how good the nylon line Autometer has, but I've had trauma w/ a punctured 1 way back.
Old Jul 22, 2018 | 10:45 PM
  #37
DamnCampers's Avatar
DamnCampers
I know you have already done testing with a guage to find out if you are getting steady pressure, but there are two other items to consider as well for the low oil pressure that i had happen. In my case the oil housing seal and heat exchanger o-rings had started to fail causing a slight drop in pressure. That was added to a leaky oil pressure switch at the same time. Switch ended up being good, but was replaced since it was a mess.
ostojo
Mar 9, 2022 01:43 PM
pnwR53S
Sep 27, 2017 03:53 PM
garthg
Oct 25, 2014 09:01 AM
BChili
Oct 11, 2011 08:53 PM
Headlands
R55 :: Clubman Talk (2008+)
Apr 2, 2010 02:23 PM
