R53 not acting right
Old Jul 16, 2018 | 04:14 AM
MikeR6453's Avatar
MikeR6453
I need some help guys. I like to think Im decently mechanically inclined but Im struggling right now.
My '03 MCS "R53" has been acting up. Im currently at 178500 miles.
My acceleration has been sluggish when starting from a stop. And onve I get up to speed on the highway or interstate "55 and up" my throttle response has turned to ****. If the road starts going uphill "even a small incline" my speed will drop noticably and will not respond to throttle. I will have to downshift to about 4th and sometimes 3rd to keepfrom getting ran over.
my MPG has dropped immensly as well. I have gone from about 28- 30 MPG to around 18 MPG.
This is my daily and only car so I need some help please Im at a loss.Not sure where to start. Had a light that gave me code for cat but that just went away and not sure where to go now.
Old Jul 16, 2018 | 04:45 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues section.
Long distance diagnosing is not to easy but some possibilities in no specific order: crank pulley, bypass valve or plugged cat.
Old Jul 16, 2018 | 06:13 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Do you have a 'burnt rubber' smell emanating from the engine compartment? If so, your problem is likely a failed/failing crankshaft pulley.
Old Jul 16, 2018 | 07:37 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
A partially-clogged cat will certainly affect performance like you're experiencing but it should throw a code. First, I'd take a compression test to see if your engine is in need of a re-build. If it passes compression test, then drop the exhaust to check the cat for blockage.
Old Jul 16, 2018 | 08:15 AM
MikeR6453's Avatar
MikeR6453
No smell coming from engine.and just changed belt 2 mths ago when. Idler pulley bearings failed.
Old Jul 16, 2018 | 08:24 AM
Dave.O's Avatar
Dave.O
Have you ever changed the clutch, air filter, plugs. It could be several things .
Old Jul 17, 2018 | 04:56 AM
MikeR6453's Avatar
MikeR6453
I was finally sble to get under it last night and popped the cat with the heel of my hand. And it sounds like rocks in there so I guess the substrate broke off and is clogging it up. FML
rharris19
Classic Mini Talk
Mar 27, 2012 08:24 PM
Applellial
Cooper (non S)
Feb 21, 2011 05:49 AM
zeus7625
Jun 12, 2010 04:38 AM
ryubrg
Dec 21, 2008 04:04 PM
mrbean
Oct 16, 2003 09:01 AM
