AC Recharging Issue
Old Jul 14, 2018 | 01:59 PM
lazabby's Avatar
lazabby
AC Recharging Issue
My Mini is not blowing cool. I put gauges on it and with adding a little bit of R134a, the low pressure is about 42 and high pressure is about 120 which is too low. Ambient temperature is about 85-90 degrees. Inside air from the event is in the 80s so it's not cooling. Any ideas what is going on?
Old Jul 14, 2018 | 02:16 PM
cavaliers60's Avatar
cavaliers60
Either needs more Freon to get to correct temp, which if it is not holding Freon then you have a leak somewhere. If not, it could be your compressor is shot.
Old Jul 16, 2018 | 05:15 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues section.
There is a good video on what the gauge readings mean in item # 20 of the below thread.
https://www.northamericanmotoring.co...questions.html
pcap
Oct 11, 2009 09:30 AM
john411
Aug 2, 2009 06:08 PM
dtr
26
Mar 5, 2007 05:31 PM
armandCooperS04
Nov 24, 2005 08:30 PM
sjwass
Jun 11, 2005 06:44 AM
