Mini Cooper 2010
Old Jul 10, 2018 | 10:00 AM
FreddyGomez450's Avatar
FreddyGomez450
Mini Cooper 2010
My Mini doesn't want to start.
1.keyfob is inserted but I get no lights or power, so I thought it was the battery.
2.battery is brand new, bought it this year. I've been to AutoZone, O'Rilly's, Pep Boys and Interstate Batteries and all of them said the battery is working great.
I'm thinking it might be something electrical
Does anybody know what could be wrong?
Old Jul 12, 2018 | 08:31 AM
MiniToBe's Avatar
MiniToBe
welcome aboard...
Can you use a test light to see if power is actually getting to the fuse box under the hood and the other fuse box behind the passenger kick panel?
where're you located?
Old Jul 12, 2018 | 09:37 AM
FreddyGomez450
Originally Posted by MiniToBe
welcome aboard...
let me try that out , and I’m located in the US. I tried turning it on today and it started and ran fine. But sometimes it just randomly doesn’t want to start
Old Jul 12, 2018 | 10:29 AM
MiniToBe's Avatar
MiniToBe
oh...if that is the case, I have a feeling it the fuse box behind the pas. kick panel...these symptoms resemble few of the flooded minis I got.
you have a sunroof?
Old Jul 12, 2018 | 01:00 PM
FreddyGomez450
I checked the fuses on the passages and they all work fine, and yes I have a sun roof . I did notice one of the fuses gets really hot
Old Jul 12, 2018 | 01:06 PM
MiniToBe's Avatar
MiniToBe
fuses might be fine, but if the communication bus is faulty, then it will miss.
Old Jul 12, 2018 | 04:59 PM
FreddyGomez450
Car key is in but nothing turns on , but the battery as mentionedis brand new. This is what I mean by it not turning on
here’s an image of what happens,
Old Jul 12, 2018 | 05:32 PM
MiniToBe's Avatar
MiniToBe
Hook jumpering cables. The battery might be dead despite being new!
This an indication the fuse box behind passenger kick panel is faulty.
Old Jul 12, 2018 | 08:33 PM
FreddyGomez450
I did , and what could be faulty about the fuse box ? an how can I fix it ?
Old Jul 12, 2018 | 08:38 PM
MiniToBe's Avatar
MiniToBe
The circuit board would be corroded and damaged. You need to find a fuse box matching the part number or at least from the same model.
Use realoem.com to locate interchangeable part numbers.
paulsminis
24
Feb 7, 2011 01:24 PM
morwen
Milwaukee MINIs
Aug 7, 2010 02:17 PM
