Vacuum
Old May 20, 2018 | 05:20 AM
asysavanh's Avatar
asysavanh
Vacuum
guys mind sharing your vacuum pressure? Mines at -18. Did the intercooler noisemaker delete. Now it’s at -21
2012 r56s n18. I keep seeing other folks at -14 or no vacuum at all.
im running the p3 obd2 gauge.
Old May 20, 2018 | 07:57 AM
squawSkiBum's Avatar
squawSkiBum
Moderator
You're referring to the intake manifold pressure from the MAP sensor?
The MAP reading on the N18s can be confusing because of the variable valve lift on the intake valves. At cold start the engine speed is regulated by the throttle body so at idle you'll see vacuum, I see around -14. Then when the engine has warmed up a bit the variable valve lift takes over and the throttle body opens all the way so the vacuum at idle jumps to about -1. I have a mechanical boost gauge that shows this, the MAP sensor reading from OBD2 shows the same thing. Somewhere there's a thread from about 3 years ago where I posted a graph from the Torque app showing this and a couple of links to some articles from BMW explaining the whole system.
Deleting the intercooler muffler (I think that's what you meant) shouldn't have any effect on this, so it could be a function of ihigher dle speed if the air temperature is colder at startup or if you have the AC turned on.
Old May 20, 2018 | 08:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you on an N18, at temperature, you shouldn't see any vacuum. (well, almost nothing)
You will only see vacuum on the N18 during cold start, and only if you let the car idle for a little while before driving. Once you start driving, engine controls go into warm mode, and no more vacuum.
I have seen anywhere between -14 to -20 during cold start on my boost gauge. So, you're normal.
Old May 20, 2018 | 02:30 PM
asysavanh's Avatar
asysavanh
Im going to pay more attention to the gauge and get back with you guys. I know for sure with AC on the vacuum decreases to -16/-17.
KerMini
Detailing 101
Dec 27, 2003 06:05 AM
MINIACK
Detailing 101
May 27, 2003 06:44 PM
Arly
Feb 5, 2003 04:49 PM
wgb113
Detailing 101
Feb 3, 2003 06:14 AM
