Help oil feed line bolt snapped stuck in block
Old Apr 27, 2018 | 09:29 PM
Brainpp's Avatar
Brainpp
like title says snapped oil feed line bolt that connects the line to the block need help ASAP how can I remove it
Old Apr 28, 2018 | 09:31 PM
BigBoost's Avatar
BigBoost
How far in the block is it broken.
Old Apr 28, 2018 | 10:55 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Sounds like you need a bolt extractor kit from your local tool store. I assume you're talking about the hollow center bolt that secures the banjo fitting to the block? Should be able to get the right size extractor bit into that and back it out.
Old Apr 30, 2018 | 08:54 AM
MiniToBe's Avatar
MiniToBe
also try a pick...slow and stead tap it in an angular motion counter clockwise.
Everyday I'm Motorin
Mar 29, 2019 04:54 PM
Whyismyhaironfire
Apr 15, 2018 07:37 AM
Blake Pitney
R55 :: Clubman Talk (2008+)
Dec 9, 2016 07:16 AM
Blake Pitney
Dec 2, 2016 08:30 AM
indianainline
Nov 20, 2016 09:26 PM
