P2096 code
Old Apr 22, 2018 | 04:55 PM
speedman's Avatar
speedman
P2096 code
i have searched the forum for an answer to this P2096 code. My R53 threw this code yesterday and I cleared it but the is a pending P2096 I cannot clear. I have read here that TSB states not to replace the O2 sensors. I am trying to find out what I need to check and how I make this code go away. My car has 130k on it now so it could be a number of things. Any please on where to start would be great
Old Apr 22, 2018 | 06:03 PM
Whine not Walnuts's Avatar
Whine not Walnuts
It could be a leak around the supercharger. Have the gaskets below the throttle body ever been replaced?
Old Apr 23, 2018 | 07:37 AM
speedman's Avatar
speedman
the supercharger has never bee off the car.
Old Apr 23, 2018 | 09:08 AM
Whine not Walnuts
Suggest a pressure test, how good are you with wrenches?
Old Apr 23, 2018 | 06:12 PM
speedman's Avatar
speedman
I do all my own work
Old Apr 23, 2018 | 06:33 PM
Whine not Walnuts
Someplace there is either a thread or a video on making your own pressure testing boot by buying some pvc fittings at a hardware store. You can buy the thing on line as well. You put in the hose that goes from the air cleaner to the throttle body. I found I had some good leaks around the BPV. Took off the euro clamps and replaced them worm drive.
Below is what I made, 2 1/2" PVC end cap. In the middle of making getting a second Cat made up for my OBX header so work bench is a mess.
Old Apr 23, 2018 | 08:15 PM
kaneguy's Avatar
kaneguy
The P2096 code is one of those codes that cannot be cleared by an over the counter OBDII scanners. It has to be cleared by the dealer or shop that has one of those special diagnostic machines. I had WayMotorWorks clear mine a few months back. I would get a ODBII scanner that can graph the output voltage of both pre and post O2 sensors to ensure everything is working correct. I used the Pro Torque app on my android phone. It works pretty good. The pre cat O2 sensor voltage should swing between .1 and .8 v as the ECU compensates rich and lean conditions. The post cat O2 sensor voltage should be fairly steady around .4v - .6v when running at steady speed. This displays that the cat is working properly. You can spend a lot of cash by blindly replacing stuff. Get the right tool so you can correctly diagnosis the issue.
Old Apr 24, 2018 | 05:11 AM
speedman's Avatar
speedman
Thanks for the great input. i will start working on the problem
Old Apr 24, 2018 | 10:20 AM
Zsm's Avatar
Zsm
My kid’s R53 also ran into this code. I checked for vacuum leaks, cleaned the MAP sensors and all the other things to check.
Ended up being the precat O2 sensor. It had likely never been changed in 220K miles.
It took about a week of driving for the code to finally go away. Drive cycles is also a way for a pending code to be resolved.
Old Apr 25, 2018 | 09:36 PM
gpwpat's Avatar
gpwpat
I have had this code twice. Both on diffent r53. Both times it was a hairline crack on the header
ignote
Feb 22, 2019 06:02 AM
hardestyal
Sep 29, 2014 02:55 PM
gary87xj6
Jan 26, 2013 04:13 PM
Iron-Iceberg
Jan 26, 2011 03:38 AM
RCorney17
Jan 6, 2011 12:42 AM
