Auto trans slippage, fluid leak
Old Apr 20, 2018 | 12:21 PM
Frogerelli's Avatar
Frogerelli
Hello,
I have a 2005 R52 with auto transmission. I had the transmission rebuilt a year ago. It has performed reliably since then.
Today, suddenly, I stepped on the gas and the engine practically just spun. I more or less coasted about 1/4 mile, looking for a place to park and check things out. No unusual sounds. I put it in reverse and it seemed solid, but drive slipped. I looked underneath and there was a steady drip of fluid coming out up by the radiator.
As far as I know, it is a sealed system so I can't simply pour in some fluid and see if that is the problem.
Thoughts and suggestions? (Car is currently parked at a local library)
Old Apr 20, 2018 | 12:23 PM
Frogerelli's Avatar
Frogerelli
Also, what kind of fluid should be used in the transmission?
Old Apr 20, 2018 | 12:57 PM
Doug1066's Avatar
Doug1066
Castrol Transmax Multi Import or Aisin ATF or Mobil 1 ATF, as long as the fluid meets the JWS-3009 standard.
GSequoia
Sep 23, 2013 05:33 PM
that7guy
Feb 11, 2010 11:04 PM
sequence
Jan 23, 2009 06:11 AM
RSXtoMCS
Sep 18, 2008 08:27 PM
