Oil cooler housing gaskets or something else?
Old Apr 11, 2018 | 07:13 PM
mabbonizio's Avatar
mabbonizio
My 2007 Cooper base developed a nice oil leak a last week. I presumed it was the valve cover gasket since I pulled it to check the timing chain guides and tensioner and thought I may have damaged the gasket. Replaced it and still have a leak. Only enough the lek has slowed down.. perhaps both seals where leaking.
Oil pools on the bottom of the pan, drips on the down pipe, and on the bell housing. Seems to leak some times after sitting for a few hours and leaks worse when cold. Once the motor is warmed up it does not leak.
Anyways..
There are alot of DIYs for the turbo models but non for the Justas.. any tips or tricks for replacing the oil filter housing gasket seals on the N12?
I will be changing the water pump which has a minor leak at the same time.
Old Apr 12, 2018 | 06:22 AM
N12 Engine MINI Cooper Oil filter housing gasket DIY is here: 11428643758
https://www.northamericanmotoring.co...g-gaskets.html
Old Apr 12, 2018 | 06:56 AM
mabbonizio's Avatar
mabbonizio
Thanks!
To add to the confusion I peaked under the car this morning and there where no oil spots on the ground... hmmm this leak is starting to drive me crazy. Not sure what could be intermittently leaking oil.
Old Apr 12, 2018 | 07:11 AM
Welcome,
Could be on and off as the gasket swells. Like its just in the starting phase.
Old Apr 15, 2018 | 06:19 AM
bugeye1031's Avatar
bugeye1031
Moderator
It could be the vacuum pump O ring....this is a common problem. I like to replace the pump and O ring at about 100,000 miles...to prevent any problems if the pump freezes. This approach is probably overkill....
Just changing the O ring is possible as well.
Removing the vacuum pump isn't difficult....
Old Apr 16, 2018 | 11:32 AM
BigBoost's Avatar
BigBoost
Head over to Detroit Tuned Chad will work you up with what you need!
Whyismyhaironfire
Apr 15, 2018 07:37 AM
DRoc7822
Feb 11, 2017 08:39 AM
imncrxtc
Feb 2, 2017 11:31 AM
Provo2014
Feb 12, 2016 08:19 AM
VtwinPower
Oct 26, 2010 09:44 AM
