Wheel speed sensor price range. Which brand?
Old Apr 10, 2018 | 09:20 AM
Goop's Avatar
Goop
In need of a new LF wheel speed sensor. I see there is a WIDE price range for this part, $16-120. Crazy!
I want a good quality part but I don't want to pay over $100 if I don't have too.
Reputable brands? Anyone have bad experience with the lower priced units?
Old Apr 10, 2018 | 10:33 AM
RUPNOK's Avatar
RUPNOK
https://www.northamericanmotoring.co...nsor-code.html
Old Apr 11, 2018 | 11:15 AM
I have used the Genuine ones and VDO "which is the genuine one". What you really have the watch is on install, you can break the head on the lower and higher cost ones the same.
https://www.northamericanmotoring.co...ed-sensor.html
Old Apr 11, 2018 | 10:54 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Learnt some tribal knowledge on these wheel speed sensor tonight. Pricey sensor does not necessarily mean better than cheap ones. The failure often is due to the rusted hole cause the sensor to be damaged when installing.
Old Apr 12, 2018 | 05:07 AM
Yep,
I done it before and was stuck with a VDO unit that failed only to find out it cracked and split the sensor head in half. I hit the dang hole with sand paper on a pneumatic tool and cleaned that rusty knuckle out. Then the sensor slid all the way in and down fine.
Old Apr 21, 2018 | 08:57 PM
Goop's Avatar
Goop
Bought the cheap $16 off Amaon. Works fine so far.
Jwp2
Jul 22, 2019 10:42 AM
WillM
May 30, 2018 06:01 AM
Racingguy04
Oct 6, 2014 08:13 AM
eagle
Mar 23, 2014 12:48 PM
Mini_Chan
Oct 7, 2007 09:56 PM
