No AC and No fans
Old Apr 21, 2018 | 09:01 AM
drumstick's Avatar
drumstick
No AC and No fans
Hi guys I'm new to the forums.
I just got my wifes 2006 Mini out of storage and having some issues with all the fans and ac. While driving back home the car started to overheat. The cooling fan (low/high) doesn't work, power steering fan doesn't work, ac/condenser fan doesn't work. When I turn the ac on, I don't hear or see the compressor clutch engaging. Fuses look good. Would a bad ac compressor cause all the fans not to work as well?
Thanks!
Old Apr 21, 2018 | 03:57 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you the Stock Problems/Issues area.
First, is there voltage to each of the above? What is the voltage of the battery with the car off and the car on? Have you checked the engine area fuse box? The power steering fuse is on the bottom side of the engine area fuse box.
Old Apr 21, 2018 | 04:03 PM
drumstick's Avatar
drumstick
i haven’t had the time to check battery voltage yet or if there’s power to the fans yet. I will be tomorrow. So far I only checked f5 fuse in the engine bay fuse box from what I saw on here but it’s not blown.
Old Apr 21, 2018 | 04:07 PM
Whine not Walnuts
Need to check the voltages and then the relays.
Old Apr 22, 2018 | 10:25 AM
Eric_Rowland's Avatar
Eric_Rowland
Dead AC compressor is indicated by the low speed fan not going on, but the relay is usually the cause. Relay wouldn't be a high speed fan issue.
valcom111t
Off-Topic :: Autos
29
Jul 11, 2007 12:33 PM
RobbyD
Aug 22, 2005 05:01 PM
