P0500 vehicle speed sensor code problem
Old Apr 4, 2018 | 05:03 AM
Supertractor3's Avatar
Supertractor3
Good morning everyone.
Recently, I have been treated to a bit of a challenge with my 06 R53 JCW manual Trans. The SES came on and I checked to see what the problem was with my diagnostic tool. I use an I scan 2 WT so I have very good access to all vehicle modules.
So I have no other codes anywhere in the vehicle, and my data stream shows all 4 wheel speed sensors reading correctly and accurate at all speeds. A detailed inspection of the wheel speed sensors didn't really show anything of consequence, but my front wheel bearings felt a bit noisy. I just sucked it up and replaced both front wheel speed sensors and wheel bearing hubs. To no avail, the SES remains with a lone P0500. Rear bearings appear to be tight and quiet.
The vehicle runs fine otherwise. No other warning lights activated, no performance issues and no other codes. I can't see where there is any transmission mounted VSS so I am at a bit of a loss as th what is going on here. This does not seem to be consistent with others who have this code pop up.
This vehicle sits for the winter and I did have to use my booster pack on her a couple weeks ago, but I have been driving it for those couple weeks with no lights or problems. I also recently mounted 4 new pilot sports (stock size), a new belt and tensioner and an oil change. She also got a new set of low pressure P/S hoses.
Any thoughts?
Old Apr 4, 2018 | 05:13 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Gen1 Stock Problems/Issues area.
Battery is good?
Old Apr 4, 2018 | 05:47 AM
Supertractor3
Thank you WnW
Yes, battery has been tested, known good, even tried it with a brand new battery I took out of my 06 R50. Same story.
Old Apr 6, 2018 | 06:18 PM
Supertractor3
Adaptive reset performed, problem resolved.
Old May 17, 2018 | 07:14 AM
Docsigns's Avatar
Docsigns
So... clearing adaptations will resolve this issue?
Rahmanz
Oct 17, 2023 08:37 AM
pmanliu
Apr 7, 2018 03:23 PM
quickquest88
May 14, 2015 07:41 PM
pocketmaster
Sep 30, 2012 06:36 AM
jtara
R55 :: Clubman Talk (2008+)
Apr 20, 2010 07:11 PM
