Oil filter housing gasket repaired now P0300 CEL
Old Mar 21, 2018 | 07:11 PM
thinwall's Avatar
thinwall
I have just finished fixing the oil filter housing leak and replacing the turbo oil feed and return line. I go to start it, it starts fine but has serious rough idle and CEL P0300, P0301, P0302, P0303, P0304. I have looked and checked everything I can think and everything thing seems to be fine. The MCS ran fine without any problems except the oil leak prior to now. I'm not completely sure I have the gasket on correctly that goes between the downtube to exhaust but I don't think that would cause this problem, but I could be wrong. Does anybody have an idea what could be causing this? Thanks ahead of time for any help.
Old Mar 23, 2018 | 12:16 PM
MiniToBe's Avatar
MiniToBe
I suppose you filled the oil and put coolant and bled the system?
erase the codes and see what pops back. if the same, then check the wring again and perhaps the ground strap on the motor mount and the little one on the valve cover.
Old Mar 23, 2018 | 07:33 PM
Minimonsta22's Avatar
Minimonsta22
did you mix up the thermostat and intake air temp sensor connectors?
Old Mar 26, 2018 | 05:28 PM
thinwall's Avatar
thinwall
Yes I did refill the oil and added more coolant along with bleeding. I cleared the codes and they came back. Went and checked all the connections and can' find one that isn' plugged in or crossed. Went ahead and changed tge plugs because it can't hurt and that didn't help. I'm at a loss.
mbwicz
How to
324
Jan 26, 2026 06:22 AM
trwxxa
Nov 23, 2016 01:28 PM
girubato1
Jan 26, 2015 09:48 AM
CobraBob
Apr 21, 2014 06:59 AM
DTSJR
Jan 31, 2011 03:37 PM
