Rubber engine mount bushing bad?
Old Mar 18, 2018 | 11:45 AM
ewgoforth's Avatar
ewgoforth
Hi,
I was changing the serpentine belt tensioner on my 2003 R53. In order to get access I needed to remove the engine mount bracket, which I'd taken off a few months ago to replace the camshaft position sensor. This time I noticed that the top part of the mount that has the stud mounted to it was separated from the bottom part.
Will the weight of the engine keep this pushed together? I think this part would be okay if it were always in compression, but it wouldn't be good if this was ever in tension. What is the rubber buffer or whatever called?
Also it appears to be attached by the frame underneath by some kind of small star shaped bolt. Kind of like the end of a torx fastener. Anybody know what tool will remove it? I'm hoping a small 12 point metric socket.
Thanks,
Eric
Old Mar 18, 2018 | 01:07 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Stock Problems/Issues section.
For me, yes you should change that support out and yes it might come off with a socket but that bolt is made for an external torx socket.
Old Mar 18, 2018 | 01:46 PM
ewgoforth's Avatar
ewgoforth
Know what size external torx socket?
Old Mar 18, 2018 | 02:30 PM
Whine not Walnuts
Pretty sure that is a M10 bolt but off the top of my head cannot remember the torx size. I have the car jacked up, working on a lower motor mount, will check it out and post the size a little later.
Old Mar 18, 2018 | 04:04 PM
Whine not Walnuts
You should be a T12
Brownshoe
12
Apr 12, 2019 06:27 AM
Andrew Riley
Dec 31, 2015 08:23 AM
coopspeed
Feb 8, 2013 09:51 AM
sprp85
Jan 22, 2009 09:13 AM
verveAbsolut
Nov 20, 2007 08:27 PM
