turbo motor from a 2012 R55 Sinto a 2011 R56 S HALP PLEASE
Old Jun 14, 2018 | 12:59 PM
  #26
jpauley's Avatar
jpauley
Ohhh I’m definitely not saying your wrong I’m fully assuming that the info I had prior to now was bad. Easyish *** though. Which way do you fill the trans? I’ve been using the 12mm bolt on the side of the trans case.
Old Jun 14, 2018 | 01:10 PM
  #27
MiniToBe's Avatar
MiniToBe
you should use the T55 one in the back facing the power steering motor. It is hard to break but airtools make it easy...I used to unbolt the rear motor mount to get more space
Old Jun 17, 2018 | 04:24 PM
  #28
jpauley's Avatar
jpauley
So I check the fluid with the car running but can I add the fluid with the car running?
Old Jun 18, 2018 | 05:57 AM
  #29
MiniToBe's Avatar
MiniToBe
Sorry for the late response....yes you can add fluid while running...once it starts to trickle from the drain plug, close it, run through the gears slowly then check fluid again. Add a little bit this time and once it trickles, close it and take it for a drive.
Old Jun 20, 2018 | 08:10 PM
  #30
jpauley's Avatar
jpauley
Your a genius! I did it the way you said and ended up getting 1.5 more quarts in now it runs great.
Old Jun 20, 2018 | 08:36 PM
  #31
MiniToBe's Avatar
MiniToBe
Im happy I was able to help
Old Jun 20, 2018 | 09:53 PM
  #32
jpauley's Avatar
jpauley
It’s funny I have a group of guys who hang at my shop they see me go through this and keep saying things like “never again dude” I’m here thinking I learned a ton and next time it will be way easier. I appreciate all the knowledge and help I gained here. Now I have to put a down pipe, cat back, and hpfp in a R56-S manual. I kinda like these things to be honest now that this one is shifting good it’s a riot to drive.
grueinthebox
May 25, 2019 10:46 AM
skakid812
Dec 26, 2009 10:19 PM
Mr. S.
Nov 10, 2009 03:57 PM
austinapril
Jun 12, 2008 08:09 PM
ChrisLaw
Bluegrass MINIs (Kentucky)
Jan 16, 2008 06:19 PM
