chasing PS leak(s)
Old Feb 13, 2018 | 12:31 PM
dnsherrill's Avatar
dnsherrill
chasing PS leak(s)
2004 6 speed MCS, 168k miles; PS pump and fan replaced under warranty by Mini dealer in Charlotte NC, USA at 163k miles and less than 2 years ago.
I've had the car 2 weeks and about 500 miles. No indication any PS lines have ever been replaced, assume they reused originals when replacing pump.
I just cleaned up the PS reservoir, cap and low pressure hoses to the best of my ability. After driving about 30 miles the first evidence of seepage is shown here at the top of this hose below the reservoir. Thus far, EVERYTHING else appears dry.
Before cleaning there was substantial fluid around the cap and sides of the reservoir. I've ordered the o ring for the cap
Old Feb 13, 2018 | 12:46 PM
nkfry's Avatar
nkfry
We replace all of the factory crimp clamps with worm style clamps any time we are in the area. Those crimp clamps lose their hold after years and will leak.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 13, 2018 | 12:55 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
168K original hoses, you would suspect they are past useful life. I've had BMW's with the same parts and at 100K they were seeping and weeping. Clamps OEM or worm type didn't help. I'd probably try a new clamp first.
Old Feb 13, 2018 | 01:24 PM
dnsherrill's Avatar
dnsherrill
may or may not be relevant...car has lived it's entire life in the Charlotte NC area, hot summers but pretty mild winters....not much snow at all.
Old Feb 13, 2018 | 01:30 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
The leak is likely not from the clamps. They weep thru the hose wall. This is not a problem unique to Mini. I took me forever to realized it in my other car. I am not an ASE trained automotive tech. Probably share the same crap OEM supplier.
Old Feb 13, 2018 | 01:55 PM
dnsherrill's Avatar
dnsherrill
I found the DIY write up for hose replacement on the NAM site....is using Febi Bilstein CHF S11 fluid with or instead of Pentosin CHF S11 fluid ok?
Old Feb 13, 2018 | 02:16 PM
dnsherrill's Avatar
dnsherrill
More evidence, after sitting 8 hours
Old Feb 15, 2018 | 09:04 AM
Zsm's Avatar
Zsm
Replace the hoses and use new clamps. No more leak!
Once you solve that leak, you'll be treated to the next of many other opportunities to sleuth out where the other leaks are coming from...and there are many!
Old Feb 18, 2018 | 06:23 AM
dnsherrill's Avatar
dnsherrill
replaced just the clamp a few days ago....so far so good (dry)
Old Feb 21, 2018 | 07:08 AM
This ones good and yes as long as its CHF S11 fluid you are fine.
https://www.northamericanmotoring.co...hose-pics.html
and
https://www.northamericanmotoring.co...se-pics-3.html
sherman89
22
Dec 30, 2016 12:28 PM
Jersey_Bill
May 24, 2006 02:25 AM
