R52 S leak B/W slave and slave line question
Old Feb 11, 2018 | 07:14 PM
Ken Garchow's Avatar
Ken Garchow
my 05 r52 S started having clutch issues few days ago, clutch pedal went the floor with out disengaging the clutch, was able to pull pedal back up and worked for rest of the day
happened again a few times so i started looking for the problem, turns out the line from the master to the slave has a leak where it plugs into the slave. when pulled the line the O ring type seal wasn't on the end of the line but it was in the slave cylinder sideways
thought possibly it wasn't installed right, so fished the seal out of the slave installed on the line, bleed the system still had the leak
any tips how to diagnose what the sealing issue is?
cracked master, bad seal or damaged line?
thanks
Old Feb 11, 2018 | 10:40 PM
Ken Garchow
problem may be solved
decided to take apart again and take another look. what i m seeing on the seal is that it looks like it snaps on to the line first then u put the line in the slave
first time i just slid the seal on, the time i snapped it on the line than inserted in the slave. so far no leak
not sure why it wasn't leaking then it just started a few days go but will see if this solves the issue
Old Feb 12, 2018 | 07:08 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the seal snaps on the line in the groove otherwise it will leak. The only way to get it later if need is to replace the line
https://www.waymotorworks.com/clutch...-cooper-s.html
Old Feb 12, 2018 | 07:12 AM
Ken Garchow
thanks for the conformation on that
Fir3Chi3f
Oct 3, 2016 07:46 AM
R56BrgMcs
Dec 26, 2015 09:56 PM
th3band1t
Dec 8, 2012 10:59 AM
FeedBack
Site Feedback
Feb 26, 2007 09:55 AM
