Clearing hard codes and adaptations INPA
Old Jan 24, 2018 | 04:57 PM
PhilliCooper's Avatar
PhilliCooper
I got a cable, older laptop running XP, and INPA but I'm having trouble clearing the codes and adaptations. I have a P2096 and when I clear it the code doesn't exactly clear (and I don't mean starting the car again). It'll give the cleared prompt but when I hit read codes immediately after there it is again. Also, I cleared out my adaptations and the car didn't run any differently. From what I've read that shouldn't be the case.
Old Jan 24, 2018 | 06:17 PM
Whine not Walnuts's Avatar
Whine not Walnuts
It could be that your O2 sensor is bad. Thinking 2096 is the rear sensor.
Old Jan 24, 2018 | 06:33 PM
PhilliCooper
It is the rear sensor. It's new and after replacing it cleared the other o2 codes but this one stayed. I understand that if the issue is still present then the code will immediately come back upon the next start up but it's not allowing me to clear it. Am I doing something wrong within INPA?
Old Jan 25, 2018 | 04:41 AM
Whine not Walnuts
I am thinking that Mega72 is into INPA. Might want to drop him a PM.
Old Aug 27, 2018 | 06:03 PM
dnsherrill's Avatar
dnsherrill
I'm new to INPA, will this program function better with XP than it will with WIN 7,8,10 64 bit? recently obtained the cable and software from Bcables......struggling thus far
Old Aug 27, 2018 | 06:05 PM
Whine not Walnuts
I have it on 10, you have the "switchable" dcan cable?
Old Aug 27, 2018 | 06:07 PM
Whine not Walnuts
I had to cut and paste some of my INPA folders into ISTA to make it work. Same folder names but the verbiage in my ISTA did not match what my instructions were showing. I opened up my older INPA and they matched so I pulled them over and replaced.
Old Aug 27, 2018 | 06:29 PM
dnsherrill's Avatar
dnsherrill
switchable K+DCAN (INPA compatible) from Bcables.......if i understand correctly, KCAN for pre 2008, DCAN for 2008 and newer
Old Aug 27, 2018 | 06:39 PM
Whine not Walnuts
Yep. Everything on the PDF instructions matched what you saw when you pulled your files up, correct?
Old Aug 27, 2018 | 07:12 PM
dnsherrill's Avatar
dnsherrill
yes, pretty much....I found the DCAN.exe (to set cable mode) from the Reference Manual button on the Bcables Launcher . When opening INPA it's SHIFT+F4 for Mini R50....it doesn't specify R53 or R52....just lumps them all as R50...but it shows battery and ignition on, and it id's my vin correctly...I guess I just need to study it and work with it
evano
Apr 2, 2019 01:02 PM
mikes603
Sep 11, 2015 11:00 AM
robbo mcs
Sep 28, 2013 08:02 AM
SuprCoop
PDX MINI Club
Jan 29, 2012 06:55 PM
Klasse Act
May 24, 2007 10:08 PM
