HELP!! Replaced clutch 2000 miles ago now car won't move
Old Jan 19, 2018 | 02:23 PM
Kirk Fox's Avatar
Kirk Fox
Hello to anyone who sees this. I have a 2004 Mini Cooper that just had its clutch replaced 2000 miles ago. The other day I was taking off from a stop let the clutch out pushed the clutch in and shifted to second gear but nothing happened . The linkages are working properly because i looked at them and had replaced the cables when I replaced the clutch. Now the car can be in gear and it acts like it's still in neutral . ANY IDEAS???!!
Old Jan 19, 2018 | 02:31 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Originally Posted by Kirk Fox
Hello to anyone who sees this. I have a 2004 Mini Cooper that just had its clutch replaced 2000 miles ago. The other day I was taking off from a stop let the clutch out pushed the clutch in and shifted to second gear but nothing happened . The linkages are working properly because i looked at them and had replaced the cables when I replaced the clutch. Now the car can be in gear and it acts like slurs in neutral . ANY IDEAS???!!
One possibility. Driver side axle not properly seated by the novice mechanic and ruined the spline. This happened a number of times.
Old Jan 21, 2018 | 05:13 AM
Kirk Fox's Avatar
Kirk Fox
Would that still be the case if I have a limited slip diff?
Old Jan 26, 2018 | 01:14 PM
nkfry's Avatar
nkfry
If either of the axles aren't properly locked into the diff or bolted in you can/will lose drive ability. The passenger axle bolts to the engine block with 3 13mm bolts and the drivers side axle is retained in the differential carrier by a circlip, if either of those retention methods are compromised you will have issues.
Are you able to shift between gears with the car running and not grind gears?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 26, 2018 | 03:36 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Its always good to have a vendor like Detroit Tuned that not only sells MINI parts, but fixes MINIs.
Old Jul 6, 2018 | 06:41 PM
BATTLEMINI's Avatar
BATTLEMINI
Wish they would have followed up on this thread. I just replaced the clutch with a Valeo unit and now the car wont move.
KevinR
Apr 2, 2016 08:31 AM
howieschoon
Jun 4, 2014 09:15 PM
battalion360
Feb 28, 2013 01:39 PM
TDeadrick
MINIs and Minis for Sale (archive)
12
Apr 11, 2008 08:11 AM
saxman
May 25, 2007 03:45 PM
