Noise
Old Dec 26, 2017 | 09:49 AM
phh06's Avatar
phh06
Noise
Am having noise problems from pax side of 06MCS when backing up. Also lot of noise on same side when hard turns made. Any suggestion?
Old Dec 26, 2017 | 10:27 AM
gumbedamit's Avatar
gumbedamit
Lower Control Arm Bushing
Inner Ball Joints
CV Joint
Old Dec 28, 2017 | 11:32 AM
CSP's Avatar
CSP
Really going to depend on what the noise is. Could be as simple as rubbing.
Old Dec 28, 2017 | 04:35 PM
phh06's Avatar
phh06
Changed lower control rod bushing. Checked for rubbing. Only happens at various times. Turn to right out of parking, Left turn backing etc. Having struts replaced to see if this corrects problem.
Old Dec 29, 2017 | 06:38 AM
Whine not Walnuts's Avatar
Whine not Walnuts
How many miles? What location is the car located (reason salt rot)?
Old Dec 29, 2017 | 05:33 PM
phh06's Avatar
phh06
65K Located in Southeast for life from history of title.
I am second owner bought with little over 63K on vehicle.
Has become a money pit.
Whoever had before me did not take care of maintenance.
Old Dec 29, 2017 | 05:39 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Just to eliminate it, check your wheel bearings. Jack up passenger side. Grab wheel at 12 and 6 o'clock. Press in at top, pull out at bottom, then vice-versa. Excessive play indicates your problem.
Old Dec 30, 2017 | 04:57 AM
Whine not Walnuts
With the miles and lack of salt, thinking like the trackrat, check the wheel bearings.
Old Jan 2, 2018 | 07:39 AM
phh06's Avatar
phh06
May have found problem. RH side shock busted at top near mount. 2 new shocks and mounts later seems to what Charlie needed.
Once again thanks for all the good input for troubleshooting.
rickyr53
Dec 16, 2010 10:21 PM
mcs1984
Jan 1, 2010 04:52 PM
paul8345
Feb 18, 2008 05:35 PM
ficcion
Feb 4, 2008 08:00 PM
