How to restart timing from scratch
Old Dec 16, 2017 | 06:09 PM
Jake Renninger's Avatar
Jake Renninger
So while I was redoing my sprockets, chain, and guides, I marked off with a Sharpie the direction in which the arrows were pointing. By the end of my project I noticed both were wiped off. I also know that I did turn the camshaft in order to get the tool on to get the bolt on snug. I did match up the gold links with all of the arrows but I'm not guaranteed good timing correct?? I need some good help on how to fix this!! I also don't want to be off by 180° and think that it looks right
Old Dec 17, 2017 | 05:01 AM
CRC's Avatar
CRC
Which model?
Old Dec 17, 2017 | 05:19 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I am thinking that if you had the marks in place before you did any work you are ok. Also pretty sure that the marks only line up every 4th cycle on a single cam 4-cylinder engine.
I have rebuilt a V-6 with DOHC but not a Tritec.
Old Dec 17, 2017 | 11:42 AM
Jake Renninger
Originally Posted by CRC
Which model?
it's a 2003 MCS. And I know I did turn the camshaft in order to get the tool to fit in. How can I be sure that my timing is Good? At what position does the cam have to be in relative to the crank
Old Dec 17, 2017 | 12:23 PM
Whine not Walnuts
Have to get some better mechanics involved. Might have to find TDC on the # 1 cylinder and then also whether it is in compression or exhaust. Have you done a search, even on Google, 9 of 10 times will send you back here?
Old Dec 18, 2017 | 06:53 AM
nkfry's Avatar
nkfry
Do you have the cam lock to lock the engine in time? Cam Tool Rental
It's a very simple setting. There are two dots on the crank gear that correlate with two marked links on the chain, and one arrow on the cam gear that correlates with the single marked chain link.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 18, 2017 | 07:17 AM
Whine not Walnuts
Question, as if either the cam or the crank is off by one turn you could have valves in either compression or exhaust, don't you need to make sure that you have that correct?
Old Dec 18, 2017 | 09:59 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
To get it back exact and be sure your 100% in time you will need to pull the front timing cover/oil pump and line the marks up with the copper color teeth on the chain. If you remove the rocker arms all the valves will be closed and you can turn the engine without worry of bending valves to get it lined up then install the chain and then the rockers.
Also make sure you go ahead and replce the timing cover seals as they are always smashed flat and will need replaced.
Old Dec 21, 2017 | 08:04 PM
Jake Renninger
so that's what I did with my new chain and sprocket but something I noticed on the previous parts is that the arrows weren't aligned with the gold links, so I missed them timing up trying to get the arrows and chain to line up when I shouldn't have messed with it. Is there a universal way to reset the timing? Like cylinder 1 tdc on the exhaust stroke type of thing?
Old Dec 22, 2017 | 06:25 AM
Whine not Walnuts
Would think the universal method would be only when the timing chain has not been screwed around with. If the chain is off, then there is the chance of bending a valve. Where Way said to remove the rockers is now the only thing you can do IMO.
Old Dec 22, 2017 | 06:41 PM
WayMotorWorks
Vendor
NO you do NOT time it with the piston at TDC.
If the teeth didn't line up with the arrows on the cam and the crank then it wasn't timed correctly. They HAVE to line up. Take it back apart and redo it something is wrong. And make sure you look in the manual it has several great pictures.
Old Dec 22, 2017 | 07:24 PM
Jake Renninger
so I now realized that I think I was over thinking things. I understand now that the chain spins haha. Are you saying that I'm guaranteed proper timing if I match all of the notches??
Old Dec 23, 2017 | 12:44 PM
WayMotorWorks
Vendor
yes if you line the marks up with the teeth then it will be correct.
rockridge
Aug 18, 2008 01:10 PM
gtyellojacket
Jan 9, 2008 12:49 PM
eman
Apr 5, 2005 05:17 AM
gocart29
Jul 11, 2003 07:25 PM
tmack
Jul 3, 2003 02:57 PM
