Chime / lock / key sensor
Old 11-12-2017, 01:21 PM
blackbearz's Avatar
blackbearz
blackbearz is offline
I have a 2003 Mini Cooper that has started chiming when I open my driver's side door, whether my key is in the ignition or not.
I also am not able to lock the doors with the remote.
I believe the key sensor in the ignition might not be signaling that my key has been removed from the ignition.
Does anyone have any suggestions or ideas of how I could fix this?
Thanks!
Old 11-12-2017, 04:02 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Whine not Walnuts is offline
Moving you to the Stock Problems/Issues area.
Have you done any searching here or on Google (they usually send you back here) about the matter?
Old 11-12-2017, 06:02 PM
blackbearz's Avatar
blackbearz
Yep- looked around for quite a awhile. Couldn’t find anything on here about the Mini not sensing the key has been removed, which might stop the chimes and allow the door to lock... any help would be appreciated!
Old 11-12-2017, 06:48 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
It's very possible the ignition switch is bad as we have seen many of them fail.
https://www.waymotorworks.com/igniti...0-r52-r53.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 11-14-2017, 04:03 PM
blackbearz's Avatar
blackbearz
Is there a sensor in the lock cylinder? Perhaps I could just disconnect the sensor?
Any ideas?
Old 11-14-2017, 06:31 PM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
6th Gear - NAM Hall of Fame
Any ideas?
I agree with WMW it is likely a failed ignition switch. I seriously doubt you can out fox it and still able to start the car.
Old 04-03-2018, 06:36 PM
blackbearz's Avatar
blackbearz
I replaced the ignition switch. No change.
I also replaced both door lock actuators (the only fault codes that were present on my Mini).
Still no dice.
Further information - if I disconnect the battery briefly I am able to lock / unlock the doors with the remote and the door does not chime when I open it. Once the key is put in the ignition and switched to the "on" position it happens again (door chime, unable to lock doors, etc...)
Any more ideas?
Old 04-22-2018, 06:28 AM
blackbearz's Avatar
blackbearz
* Bump *
Old 04-22-2018, 08:44 AM
Whine not Walnuts
There was a recent thread on gremlins. The question for the pros is does the key/chime signals originate from the BCM or the Kombi module.
Old 04-22-2018, 08:55 AM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
I can be wrong here. You do have a point. While the more critical functions of engine management, instrumentations are not handled by BCM, key chime and door ajar reminders type secondary connivence features are likely all handle by the BCM.
Does it has sunroof, and parked outdoors? Not being able to lock a door with remote also increase the likelihood of water intrusion that damaged the BCM. The wiring harness and connectors in our Mini's are excellent, but corrosion from water can cause problems.
Old 04-22-2018, 12:24 PM
blackbearz's Avatar
blackbearz
More information, we’ve replaced the BCM. No dice.
I’m wondering if the key lock switch in the steering column is not sensing the key has been removed? Is that possible? If so which part would the sensor be in?
Old 04-22-2018, 12:42 PM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
Me think your driver side door or any other doors closed switch may be faulty. You have been barking up the wrong trees. Have you check that?
Old 04-22-2018, 01:42 PM
Whine not Walnuts
I had a Honda S2000 that the door switch had a loose connection. PNW may have hit on something.
Old 04-22-2018, 02:12 PM
blackbearz's Avatar
blackbearz
I’m not sure if it could be the door sensor; that seems to be working just fine. It chimes when the door is open and stops when it’s closed.
Old 05-05-2018, 10:23 PM
MiniVancouver's Avatar
MiniVancouver
MiniVancouver is offline
Hello Blackbearz. My 2003 exactly has the same problem. Surprisingly I had tried that battery removal temporary fix too...
I have not been able to lock my Mini for over a year now! I thought this might help: My Mini did not have this problem, until it sat for one winter in the open parking and with the driver window open for about 1 cm, long story short in months my car was soaked with water inside and so much mold. When I tried to start the car, the key was not going in the ignition and I sprayed some electronic contact cleaner and finally got the key in and started the Mini but that door chime/remote problem started. From what you said and the history of my Mini problem I have concluded that this should be the ignition switch problem, If I get some time to open and clean the switch I will keep you updated. Thank you.
Old 05-06-2018, 12:03 PM
blackbearz's Avatar
blackbearz
Found the problem!
It was corrosion at a junction in the wiring harness near the fuse box. There were like 40+ wires coming in / out of the junction. My shop removed the junction, and soldered the wires together. The only reason there was a junction there in the first place was for convenience during the assembly of the car's wiring harness.
It wasn't cheap (like $600) for a day and a half labor but everything now works perfectly!
Old 05-06-2018, 12:06 PM
pnwR53S's Avatar
pnwR53S
pnwR53S is offline
Tell me it is not water intrusion or high moisture corrosion. Need more history and condition of the Mini.
Old 05-06-2018, 12:31 PM
blackbearz's Avatar
blackbearz
Yep, probably water intrusion. I have a sunroof. No current issue but maybe befor I bought it?
Old 05-06-2018, 04:15 PM
MiniVancouver
Blackearz, I am glad you found out the problem and thank you for your post. Was that rusty junction close to the indoor fuse box or the one under the hood?
Old 05-06-2018, 04:39 PM
blackbearz's Avatar
blackbearz
Interior. I'll post some pics of the junction / connector pieces pulled out at some point.
Old 05-10-2018, 10:35 PM
MiniVancouver
Hi Blackbearz,
Would you please post the pictures if it's not too much trouble?
Thank you.
Old 08-13-2023, 04:00 PM
Mini_coop_noob's Avatar
Mini_coop_noob
Mini_coop_noob is offline
Same problemo
I know this thread is old, but I have the exact same problem goin on! It’s driving me crazy. I’m going to check that junction you mentioned right now, along with any other nearby junctions/grounds/connections. Hopefully this solves my problem, I was actually coming here to find out where the chime speaker was so I could rip it out but I found this post. I’ll keep y’all updated!
