Foot Well Module!
  #26
Old 11-09-2020, 05:51 PM
Apexhunter's Avatar
Apexhunter
Apexhunter is offline
Yes, I got it fixed. At the recommendation from another Mini owner I checked eBay and found this guy in SoCal who did the job for $40. Can't beat that, the local foreign car repair shop wanted a minimum of $100 to diagnose and up to $1300 to "fix" the problem.
The guy I got tis from:
BMW MINI COOPER FRM3 MODULE FOOTWELL MODULE REPAIR SERVICE SHORT CIRCUIT
  #27
Old 01-10-2021, 04:13 PM
pdeinc's Avatar
pdeinc
pdeinc is offline
I don't think MiniToBe checks this thread anymore but if he does or anyone else that has his level of experience does, I have a question. When these things seem to lose their mind, has something actually failed or has the non-volatile memory been corrupted? Mine has developed issues similar to what many describe but strangely enough, some functions seem to return on their own. My issues also started when I disconnected the battery to remove the D/S seat and install a subwoofer. I also disconnect the upper connector on the FRM to be able to route speaker wires and once everything was back together, my headlight were stuck on when the engine was running, emergency flashers did not work nor did left turn signal. Also had no tail, brake or dash lights.
The windows did work and I could connect to it with an OBD scanner and Carly app and at first it was reporting defective left and right tail lights. I cleared those errors, re-ran the test and they were back. I disconnected the battery and let the car sit overnight and when I came back and reconnected the battery, some functions returned. And the Carly app now showed no errors although I still did not have brake or tail lights nor left turn signal. Headlight control returned, flashers worked, dash lights too.
So I again disconnected the battery as well as the one connector on the LRM and will test again tomorrow.
FWIW, I don't have a sunroof and there's no evidence of water anywhere. And I doubt that ebay vendor is actually troubleshooting and replacing damaged components for $41
GescomAe (07-30-2022)
  #28
Old 01-10-2021, 04:51 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Thank you for the mention
The best way I can describe what happens with frm is what happens with PCs when they through a blue screen. The main trigger seams to be a spike in voltage/current when the battery is jumped or disconnected.
the issue is pure software and unless there is physical damage, it will always be software, at lease that is what I've been dealing for far (I've done more than 10 mixed page including BMW FRMs). I do repair FRM3 (post 2009) which is done on the bench and I have my minis to test it too. FRM2 high eks (pre and including some 2009) can be reflashed or updated ON THE BENCH. These CAN be done outside of dealer intervention as previously mentioned. There are services on ebay (including mine) that care for them.
As far as your dilemma goes, it is possible, for whatever reason, that the FRM partially went koko depending on what sector of the memory got hit. I had a guy with FRM3 that his module was working perfectly but he wasn't able to code it via bimmercoding. After testing it on the bench it was partially corrupted. After the repair, bimmercoding wasn't able to code it, so we ended up upgrading the software for it to finally work.
finally, bmw/mini has an extended warranty and also check with the dealer before buying another unit.
  #29
Old 01-10-2021, 07:09 PM
pdeinc's Avatar
pdeinc
pdeinc is offline
Thanks for the quick reply with answers. I had read all two hundred plus responses on the other FRM thread but hadn't really seen specific answers to my questions. Do you think there's any chance the remaining functions will restore by themselves? Each day something else restores so am I holding out false hope? And you say you also repair FRMs in a similar state? Can you contact me through messaging to discuss this further?
Thanks again.
Ken
  #30
Old 09-15-2022, 02:59 PM
michwiththebadmini's Avatar
michwiththebadmini
michwiththebadmini is offline
Help!
I have a mini clubman 2011, my footwell module was burnt out after being dropped at a auto audio place for CarPlay installment. I picked it up and the windows, tail light, locks etc don’t work and headlights don’t turn off! They also said I had water damage and it had nothing to do with them.. although from reading all of your replies I see that it’s a common issue, are they at fault? I’m getting $1600 from dealership to fix and $600 online for a new FWM not counting installment, anybody have any input or know any places in New York (near long island) that could potentially fix the issue and not rip me off!!!
fishbert
Electrical
12-27-2020 05:09 AM
Juan Pizarro
02-06-2019 09:28 AM
Pollege96
02-24-2018 06:07 PM
Atkinsl
04-06-2017 11:05 AM
TiggerGTO
Electrical
24
04-19-2012 03:27 PM
Quick Reply: Foot Well Module!
