r56 powerfold mirror not indexing correctly
Old Nov 8, 2017 | 05:49 PM
dethbrd's Avatar
dethbrd
i did a few searches and couldnt find anything so here goes...
this week my wifes 2009 r56 factory JCW car popped up with a few new issues
every once in a great while i will accidentally fold the mirrors up, otherwise we almost never use them
tonight i borrowed the car and noticed the passenger mirror pointing outward too far, when i tried to adjust it, i found it was adjusted all the way in
upon closer inspection i noticed the powerfolder is over rotated and the mirror point too far outboard
does anyone have any ideas? reset procedure?
Old Nov 11, 2017 | 04:04 AM
MiniToBe's Avatar
MiniToBe
Perhaps the mirror head was turn by hand. Check if it sits properly on its base. Post pix of short vid.
Old Nov 11, 2017 | 09:59 AM
dethbrd's Avatar
dethbrd
ya i checked it to make sure it was seated.
its just a few degrees off from where it should and has always been.
its rotated counter-clockwise by the powerfold mirror motor so its just off center
Old Nov 11, 2017 | 10:03 AM
MiniToBe's Avatar
MiniToBe
Move it by hand to snap in place...
Old Nov 11, 2017 | 10:08 AM
dethbrd's Avatar
dethbrd
i am a mechanic
i know the mirror pops out of place if hit, as any other car does
it is not out of place
the mirror was folded up with the power motor, then when it went back, it did not index correctly
just like the power windows do in these cars sometimes
what im wondering is if there is some sort of procedure, like unhook battery, then hit button twice..... something along the lines of fixing the power windows when they stop indexing or partially opening when the door handle is pulled
Old Nov 11, 2017 | 10:14 AM
MiniToBe's Avatar
MiniToBe
Personally i dont know of any procedure to reset it. It is not quite as smart as the window module.
Is it possible that some pushed on it when it was folded and skipped teeth as a result!?
Old Nov 11, 2017 | 10:18 AM
dethbrd's Avatar
dethbrd
yes, anything could have happened, i have no idea because the wife drives it to work in the city
i tried (gently) to force it back into place like a mirror glass that doesnt work
it felt like i was going to break something
Old Nov 11, 2017 | 10:23 AM
MiniToBe's Avatar
MiniToBe
I think your next step is to take it apart to examine the internal. The other side is perfect, right?
Old Nov 11, 2017 | 10:59 AM
dethbrd's Avatar
dethbrd
correct
