2007 Sidewalk EML and SES light
Old Nov 1, 2017 | 07:46 AM
Sidewalksam's Avatar
Sidewalksam
Hi just started happening with the weather change. I do not have a loss of power and the super charger oil was changed a few years ago as was the damper pulley
any other reason I think I need a new gas cap would that cause an EML?
Old Nov 4, 2017 | 07:38 AM
jfrankjr's Avatar
jfrankjr
The light came on once in my wife's, when I drove it a bit hard. Was off the next day. Seems like just one of the many Mini gremlims to deal with.
Old Nov 21, 2017 | 06:39 AM
Sidewalksam
OK I have some codes P1498 which reads as an air leak at the compressor (supercharger I assume)
then the ABS codes
5E5C
5E19
5D91
5DA1
I got two new (bosch) speed sensors and for the most part the trifecta is gone but it has come on on one drive cycle since the repair
any thoughts on how to proceed with the air leak and how serious ?? car drives and feels fine.
Old Nov 21, 2017 | 12:54 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving you to the Stock Problems/Issues area.
Have you checked to make sure the boots on either end of supercharger are in place correctly?
Old Nov 21, 2017 | 02:04 PM
Sidewalksam
No and to be honest not sure I am understanding what "boots" you are referring to? the tubing running to and from the intercooler?
Old Nov 21, 2017 | 02:05 PM
Sidewalksam
also dumb question does each wheel have a speed sensor? I know only two have the brake pad sensors
Old Nov 21, 2017 | 03:08 PM
Whine not Walnuts
The boots are the black rubber sections at both ends of the supercharger. The speed sensors are light blue tubes about 3" long and are at each wheel. The brake pad wear sensor is at the driver front and passenger rear.
Old Nov 22, 2017 | 05:36 PM
Sidewalksam
thank you ! will check this weekend.
Old Nov 24, 2017 | 10:05 AM
Those boots can leak and then you loose boost. I again would check those first and the clamps to them.
https://www.northamericanmotoring.co...wer-hoses.html
