What would cause engine to shut off while driving?
Old 09-23-2017, 07:36 PM
htroberts's Avatar
htroberts
htroberts is offline
2009 R56 has just shut off a couple of times while on the road. No codes.
Not aware of any commonality. Once was after about two hours on the highway in heavy rain at night, once was after about ten minutes during a nice day.
Both times, coasted to the shoulder & tried to restart. Engine turns over but doesn't run. After 5-10 minutes sitting it starts normally & runs fine for a few weeks.
Has anyone had a similar issue? Likely causes?
Thanks in advance.
Old 09-23-2017, 11:08 PM
MannyJimenez's Avatar
MannyJimenez
MannyJimenez is offline
Dirty fuel filter.
Failing/Faulty HPFP (High Pressure Fuel Pump)
Faulty Electrical.
Throw a reader and see if there’s a code.
Old 09-24-2017, 07:10 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
Any other symptoms / driveability issues, hesitation, power loss, poor mpg ??
Old 09-24-2017, 08:27 AM
htroberts's Avatar
htroberts
Nope. Just comes out of the blue.
Old 09-24-2017, 08:29 AM
htroberts's Avatar
htroberts
Originally Posted by MannyJimenez
Dirty fuel filter.
Faulty Electrical.
No codes on a generic consumer reader. I'll take it by our mechanic's shop to have them check with a 'real' one.
Old 09-24-2017, 10:12 AM
R56devotion's Avatar
R56devotion
R56devotion is offline
There is a thread in the R55 Clubman section where this same thing has been happening to the owner. It was last traced to a faulty relay within the ignition system - nothing that showed on scan tool. They had to go hunting for it. It was not expensive to have the dealer do it - just an odd ball situation. Check out the thread and you may find your answer!
look for threads started by Jeffair10.
Jeffair10 (09-28-2017)
Old 09-25-2017, 05:47 AM
patpatpat's Avatar
patpatpat
patpatpat is offline
Check your air filter assembly. Once had the airbox filled with rat poison pellets.
Old 09-26-2017, 09:10 PM
MannyJimenez
WTF, but why?
Old 09-26-2017, 09:30 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
Just the motor turns off or the entire electrical system?
mQubed Motorsport, Manic Tuning Dealer
Old 09-27-2017, 08:56 PM
Jeffrey Dunn's Avatar
Jeffrey Dunn
Jeffrey Dunn is offline
That happens to me once on a suburban. Nobody could figure it out. It was trial and error. Gas cap? Fuel filter? We replaced the air flow sensor and that fixed it for awhile. Seems like it was some sensor that helps the engine have the correct combo of fuel and air. Good luck!
Old 09-27-2017, 09:20 PM
Minicoopersmodel's Avatar
Minicoopersmodel
Minicoopersmodel is offline
Bad spark plug installation. the spark plugs might be loose.
Old 10-23-2017, 12:16 PM
Prez50's Avatar
Prez50
Prez50 is offline
Have you found your problem? I’m having the same issues on my 2010 r56. It’s not throwing any codes. A few months ago when I started having issues it threw a p113b and couldn’t find out what is was or any info on it. Since then I’ve replaced the fuel filter, hpfp was already replaced a few months earlier, and currently I’m in the process of changing out my chain and the tensioner to see if it has anything to do with the shut off issues. Anybody have any of the same symptoms as op? Any help would be greatly appreciated.
Old 10-23-2017, 01:06 PM
R56devotion
P113
Mini mania has that listed as intake air temp sensor reading too high.
Prez50 (10-24-2017)
Old 10-24-2017, 09:47 AM
Prez50's Avatar
Prez50
Prez50 is offline
Would the intake air temp sensor cause the vehicle to shut down? We originally thought it was a temperature issue so since the thermostat had a minor crack on it we put a new one on along with a new temp sensor. The MAF was also replaced. The car ran great for a day or two and then started having the same issues but the engine ran at normal temp. As soon as we get the new chain on I will test the IAT sensor and the boost sensor. I will do more research on the intake air temp and hopefully will come up with a solution to our problem.
Old 10-24-2017, 10:30 AM
MannyJimenez
Have you checked the LPFP?
This was also replaced in my R60s
Old 10-24-2017, 10:35 AM
Prez50's Avatar
Prez50
Prez50 is offline
The pressure to the HPFP from the LPFP was tested and came up normal.
Old 10-24-2017, 10:36 AM
Prez50's Avatar
Prez50
Prez50 is offline
The code I was getting was a P113b not a P0113. Would that still have anything to do with the intake air temp?
MannyJimenez
How about the LPFP to the engine
Old 10-24-2017, 10:48 AM
Prez50's Avatar
Prez50
Prez50 is offline
I don't believe that was tested. Thought the LPFP only fed the the HPFP? Also, wouldn't that throw a code? Misfire or something?
Old 10-24-2017, 07:57 PM
one2three_us's Avatar
one2three_us
one2three_us is offline
This may sound dump and stupid. did you check the battery connectors? I remember someone have similar issue and it turns out was a lose terminal connector
Old 10-24-2017, 08:28 PM
MannyJimenez
It didn’t throw a code but it made the engine sputter and idle really rough
Old 10-25-2017, 06:55 AM
Prez50's Avatar
Prez50
Prez50 is offline
I'll check the battery later today. Ill make sure the wires and all good. I can check the LPFP but it won't be for a little while. Def post an update
Old 06-25-2018, 04:32 PM
jainy jonson's Avatar
jainy jonson
jainy jonson is offline
The Solution!!!!
Hey, I know a lot of people have been having the same issues with their R56. Welp so have I. My car kept stalling while driving for about 20 mins and at speeds of like 40+mph. I too thought it was the high pressure fuel pump as well as my coworkers (I work at a dealership). Took my car to BMW/MINI specialists and they found that the aftermarket thermostat housing that was installed was not providing accurate readings to the vehicle's computer. So my car was shutting off because the thermostat housing was telling the computer that the car was overheating (but it wasnt) so it shut off to save its self. And that is why there weren't any check engine lights! And also why I would have to wait 5-10 mins to start the car. They installed the OEM thermostat housing and it works fine now. That was my solution. Hope this helps!
BHat1Trey (06-05-2019)
Old 05-20-2019, 10:15 AM
htroberts's Avatar
htroberts
Someone sent me a PM asking if we had found a cause and I figured I should update the original thread in case anyone else was looking.
For us, it was the "fuse box". It seems like a misnomer to call this a fuse box. I think I took some photos of the inside, but I can't find them. Anyway, in addition to holding all the fuses, there were a couple of printed circuit boards inside, so it's more like a "power control computer". My guess is that there was either a cracked solder joint or a bad IC inside, but replacing the whole thing was about a $500 repair, most of which was the part, at our independent mechanic, but we had to wait for a hard enough failure that the car would stay inoperative before they could find it.
Old 06-03-2019, 07:04 PM
johncleary's Avatar
johncleary
johncleary is offline
I had the same thing with a 2012 roadster. Was told it was a computer fault that shut of the fuel pump intermittently. $1200.
