How should the water pump feel when turned by hand?
Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Not sure what the holes are for, but I'll venture a guess that coolant shouldn't be seeping from them...
FWIW, on yours, I'm not convinced that coolant is seeping out, as it appears that it's possibly coolant-stained grease/oil/smudge smeared in the orifice.
Below are the same holes on my new-in-box spare water pump.
Well, I brought the pump in the house, cleaned the goop out of the elongated hole, and ran water into it......it came squirting out of the other hole!
Crap, I dont know......
Looking over the pump, I see 2 holes that look like coolant has been coming through. What are they for?
Although it appears you've concluded that your water pump is the culprit, in my internet travels, I came across this snippet (on a non-MINI forum) that seemingly confirms the cause of your coolant leaking out the holes of your water pump.
Let us know how you made out, and if the water pump change solved your problem. All too often, when looking up an issue, one will run across threads that try and work through a process of solving the problem, only to fall short - leaving us all in the dark as the OP never confirmed HOW the issue was eventually resolved.
