Oil Filter Housing Seal leaking, $1000 to replace?
I will be replacing the oil filter housing gasket soon on my non-turbo 2008 Clubman. For those who have done it, do you recommend I replace the exhaust manifold gasket with its attached heat shield and new nuts too or can I get away with reusing the old one? Car has 68,000 miles on it. Also, is it best to go OEM for the gasket set?
IMO you dont need new nuts as long as they have not been removed before and you use a 6 point socket.
Mini uses some oddball metric size nuts and my extensive socket set did not have that size but a standard size (7/16 deep I think) is an exact fit. Again must be 6 point.
A few of the body clips are almost impossible to remove without breaking them and and I had to cut them off so this kit and other items here are really must have IMO.
Just finished replacing a leaking oil filter housing gasket seal, and changed the turbo lines while at it. The car will start but then stalls after a few seconds of rough rpms. Any thoughts about what could be wrong? I don't see any oil leaks, but some exhaust fumes from under the top heat shield. I did replace the turbo to down pipe gasket, and one of the three flange nuts. Would a leaking exhaust cause the car to stall like this? Thanks!
Diego Morales
Feb 25, 2014 09:23 PM
R50/53 Oil Leak - Any guesses?
Dizzy_Jenny
17
Oct 17, 2007 08:02 AM
