Oil pressure light at idle
Old May 17, 2016 | 02:33 PM
  #26
ColoCoug's Avatar
ColoCoug
OK, let's un-complicate things.
You have no evidence of a bad head gasket. Also, when diagnosing problems, the smart tactic is to figure out the simplest thing that could cause the problem and start there.
One thing that jumps out at me is that oil pressure sending units in many cars are notorious for dying early. You may have no problem at all other than a pressure sensing unit that is no longer accurate. That's the simple answer.
The other simple but expensive answer is a bad oil pump. So - what you NEED TO DO: get the oil pressure checked with a gauge. If it's good, then regardless of what the trouble light says, you know you're OK. You haven't done this yet, so there is no point in speculating about complex solutions like head gaskets.
Get that done.
If pressure is OK, then replace the pressure sensing unit and you'll be OK.
If pressure is NOT OK, then you have a real problem that needs to be addressed and you should park the car until it has been fixed.
Old May 17, 2016 | 02:41 PM
  #27
ShadyCoop's Avatar
ShadyCoop
Get that done.
Thanks for the advice, car is parked atm and I'm gonna get a new oem filter and gauge. We will see how the results are. I've already changed the sending unit twice, so I don't believe it's that.
Old May 17, 2016 | 02:43 PM
  #28
ShadyCoop's Avatar
ShadyCoop
Get that done.
Also, when I get the gauge, does the Bentley manual say anything about what PSI is considered "ok" ? Both while idling and driving
Old May 17, 2016 | 03:43 PM
  #29
ShadyCoop's Avatar
ShadyCoop
And does anyone have a link to a relatively inexpensive oil pressure gauge? What's needed for the install?
Old May 17, 2016 | 04:43 PM
  #30
1004ron's Avatar
1004ron
Amazon.com: 12 Pc Engine Oil Pressure Tester Gauge Diagnostic Test Kit w/ 10 Fittings 140 PSI: Automotive Amazon.com: 12 Pc Engine Oil Pressure Tester Gauge Diagnostic Test Kit w/ 10 Fittings 140 PSI: Automotive
Check with your local Autozone, because many of them have this type of thing available on loan.
See the oil pressure switch here.
I don't have the official spec, but typically >20 psi at idle and 40 - 60 psi at cruising rpm.
Old May 17, 2016 | 05:24 PM
  #31
ShadyCoop's Avatar
ShadyCoop
I might go with that, but I'm kind of leaning towards a full gauge set up now. Does anyone on here know how to install one and what exactly is needed? (adapters? tubing? etc.....)
Old May 17, 2016 | 06:15 PM
  #32
Tigger2011's Avatar
Tigger2011
Alliance Member
Check CravenSpeed. They have the adapter, sending unit and everything necessary including the gauge and a way to mount it.
Old May 18, 2016 | 08:50 AM
  #33
ashchuckton's Avatar
ashchuckton
You don't need to install a permanent gauge unless you want to.
As far as what hot pressure at idle should me I'd call Chad at Detroit Tuned or Eric at Helix & ask them. They have worked on many of these cars & should know.
Old May 18, 2016 | 02:24 PM
  #34
Did you check to make sure there is not a oil leak near it , just checking before you pressure test.
https://www.northamericanmotoring.co...replacing.html
Old May 22, 2016 | 03:21 PM
  #35
ShadyCoop's Avatar
ShadyCoop
Hey everyone sorry I was on vacation! But I've arrived back and my OEM mini filter that I got from ECS was waiting for me at home. I just did an oil change today and started it up, let it sit for 6 mins to get it to OT. Then I revved it in neutral a bit, first lower RPM for a while then I revved it high a few times. Let it sit some more to simulate the idling. I haven't seen the light pop up yet since I changed the new filter, but we will see tomorrow when I actually take it out to drive around a little. I haven't pressure tested it yet because I want to see if changing from a cheap filter works first. The old cheap filter I pulled out was horrid. It was slightly warped and really dirty after only 2500 miles. I also switched to 0w-40 synthetic oil to see if that does anything. ECS, I checked around the sensor (that I've replaced twice) and there is no oil seepage whatsoever. And no drits under the car at all after sitting in the garage for a week. We will see what results tomorrow brings! If i still get the light tomorrow, I'm gonna grab a pressure tester and do that.
Thanks!
Tyler
Old May 22, 2016 | 03:37 PM
  #36
Capt_bj's Avatar
Capt_bj
a couple of warning flags come up when I read this .....
one of the warnings about non-oe filters is the tendency to collapse .... I've installed MANY non-oe filters, from quality makers, that did not collapse .... but "cheap" ones DO and this restricts oil flow in addition to not doing their job .... DO NOT GO CHEAP on oil filters
And you switched to .... these cars are built for full synthetic .... if you but dino in it .... I dunno but me thinks NOT GOOD
Old May 22, 2016 | 03:49 PM
  #37
ShadyCoop's Avatar
ShadyCoop
I mean no offense when I say this, but I had a hard time trying to decipher what you were saying. I did switch to an OEM filter as stated before and I used 0w-40 FULL synthetic Castrol oil.
Old May 22, 2016 | 04:07 PM
  #38
E36-E46-R56lifewhuuuh?'s Avatar
Thanks!
Tyler
These guys can laugh if they want but it seriously sounds like coolant in the oil. Water is the only thing that's going to warp a filter like that aftermarket or not. As far as the source of the coolant in the oil I can't speculate but that's what it sounds like.
The only thing a pressure tester is going to tell you is if your ops is working correctly. You could just replace the ops for $25 bucks without going through the hassle of ordering a pressure tester IMO. I would have to imagine the light is correct and your oil pressure is in fact low at idle given that the ops has already been replaced several times.
I mean lets play this one out... The oil pressure gauge states that my pressure is indeed low at idle just like the light says. Great! Now what??? I mean I don't know what an exact figure is going to tell you besides the same thing the idiot light is telling you which is that your below recommended pressure specs.
It's obviously a flow problem meaning there is a restriction in the system. Oil pumps move volume they do not create pressure. Contrary to popular belief that low oil pressure is automatically from a bad pump.
You've already replaced the ops MULTIPLE times and the problem always goes away with oil filter changes and then resurfaces over time so what does that tell you?
The flow of oil is restricted through the filter. (Problem goes away every time u change the filter)
What's causing the filter to become restricted?
The only answer to that is water. If it's a small amount of water in the system it's going to take longer to become restricted to the point that your oil pressure drops below specs...
Where is the water coming from?
That's what u have to find out
Old May 22, 2016 | 04:20 PM
  #39
ShadyCoop's Avatar
ShadyCoop
Originally Posted by E36-E46-R56lifewhuuuh?
These guys can laugh if they want but it seriously sounds like coolant in the oil. Water is the only thing that's going to warp a filter like that. As far as the source of the coolant in the oil I can't speculate but that's what it sounds like.
You've already replaced the ops multiple times and the problem always goes away with oil filter changes and then resurfaces over time so what does that tell you?
The only answer to that is water. If it's a small amount of water in the system it's going to take longer to resurface
From what you're saying, it sounds like it could very well be that. I took a sample of oil while I was draining it and I'm gonna let it sit to see if the suspected coolant separates from the oil over time. I've heard of that problem with other cars being caused by either a head gasket problem or a cracked head. I haven't lost any coolant over the course of multiple months, so I'm skeptical of that problem, but who knows. Thanks for the reply and suggestion.
Tyler
Old May 22, 2016 | 04:47 PM
  #40
Tyler
In bikes the drop in coolant was very small over time, like in ML.... It doesn't take much trust me.
The watery oil was absolutely indistinguishable from normal looking oil.
The engine design was different so the source of the leak would obviously be different (on the bike it was water pump shaft seal), but these types of problems transcend different types of motors and from what you are describing I have had this same experience.
The ONLY way to tell was from a warped filter
Good luck tracing the source of the problem man
Old May 22, 2016 | 04:50 PM
  #41
ShadyCoop's Avatar
ShadyCoop
The engine design was different so the source of the leak would be different obviously, but these types of problems transcend different types of motors and I have had this same experience.
Thanks for the help I appreciate it! Now I just have to figure out what possibly could be the source of the coolant leak....anyone wanna chime in?
Old May 22, 2016 | 05:02 PM
  #42
SKI-R's Avatar
SKI-R
Are you CERTAIN there's coolant in your oil? I was getting the same 'advice' about coolant leak based on similar symptoms...2000kms after oil and OEM filter swap haven't seen the symptoms recur - not saying they won't, but start with the simple stuff before jumping to extreme conclusions. Hope you figure it out. AND I'm not laughing at the advice yet - just hoping I get the chance to!
Old May 22, 2016 | 05:05 PM
  #43
ShadyCoop's Avatar
ShadyCoop
Yeah I'm still gonna wait and see if this OEM filter fixes the problem first. I'll give it some time to soak and drive around a bit, but I don't wanna wait too long if it is something like coolant mixing. If the oil pressure light doesn't come on than my original problem is fixed. I'll keep everyone updated, but new information and advice is always appreciated!
Old May 22, 2016 | 05:22 PM
  #44
1004ron's Avatar
1004ron
Thanks!
Tyler
The bold part suggests that the initial signs are good and final conclusion will be made after a road test, ......but the thread goes off at a tangent and seems to suggest that you still believe that you have a problem?
Well, oil change and a new BMW/Mini filter appears to have solved it .
If I was to guess - I'd suggest it was an aftermarket filter causing the issue. I pulled 4L of used oil that wasn't 'clean', but it also didn't look horrible by any means. We'll see what happens over the next few weeks and few thousand kilometres....
I'll update again here if it reappears.
1600kms post oil and filter change = still good.
Old May 22, 2016 | 05:25 PM
  #45
1004ron's Avatar
1004ron
What makes you think that you have a coolant leak?
Old May 22, 2016 | 05:33 PM
  #46
ShadyCoop's Avatar
ShadyCoop
I was just discussing the possibility of it being something else. Just trying to think about the other options if the road test turns up a failure....but from what I can tell I have no symptoms of a coolant leak. As stated before I put a dry erase Mark where my coolant level was after I got the oil filter housing gasket replaced and it hasn't moved. I don't want to jump the gun and assume the problem is completely gone just yet.
Old May 22, 2016 | 05:44 PM
  #47
1004ron's Avatar
1004ron
It sure is confusing when you make comments like "Now I just have to figure out what possibly could be the source of the coolant leak....anyone wanna chime in?
Looks like you need to make another appearance. LOL
Old May 22, 2016 | 05:48 PM
  #48
ShadyCoop's Avatar
ShadyCoop
I like to think hypothetically, just in case something doesn't turn out to be the solution and I won't have to wait for replies on here. but I'll try to stay more on track with what's real and what's not.....my apologiee
Old May 22, 2016 | 06:21 PM
  #49
He's replaced the oil pressure sensor multiple times. My guess would be that this is a recurring problem by now....
Old May 22, 2016 | 06:35 PM
  #50
How many Kms did u drive after your previous oil change before the light popped up? I would expect the problem to resurface in about the same amount of mileage... Hopefully your good
