Front passenger side sound
Old Apr 30, 2016 | 04:38 PM
dmiranda's Avatar
dmiranda
I have a 2004 r53 I changed the inner and outer ball joint, shock and strut. Sound haven't changed a bit, a cluck sound every time a get a hole or the street is bumpy. My mini si not lower and everything is stock. If any body got an answer it will be awesome.
Old Apr 30, 2016 | 07:56 PM
Racingguy04's Avatar
Racingguy04
tie rod end? or maybe a bad strut mount?
Old May 3, 2016 | 11:40 AM
otfox's Avatar
otfox
There could be a ton of reasons for this, but I had a similar issue on the passenger side. The car would make an unsettling clunk over small bumps in the road.
I bought the car with 220k miles on it and it never had the ball joints replaced. It turns out a lot of suspension components were loose. I could wiggle the inner ball joint and tie rods by shaking them. I would give all the parts you replaced a good jiggle next time you have the car up. It can be hard to get a torque wrench on the inner ball joint bolts if you don't drop the subframe, so maybe that's where your problem is coming from.
Hope this helps.
Old May 5, 2016 | 06:08 AM
jamez's Avatar
jamez
+1 to what otfox said.
Did you drop the sub frame when you changed the inner balljoint? That's the only way to be able to torque the inner balljoint properly.
How about the LCA bushing? There's an easy test to show you if that needs to be replaced (standing to the side of the front of the car, put your foot on the front wheel, then push your foot on the wheel. If the wheel moves forward and back your LCA bushing is worn. The amount of it pushing varies on how badly the LCA bushing is worn.)
Did you change both sides of all the parts (inner, outter, struts and LCA's) at the same time?
Old May 5, 2016 | 08:09 AM
xsmini's Avatar
xsmini
Double check the top shock nut (the large one) if loose at all will clunk over bumps.
Nik
Old May 5, 2016 | 08:37 AM
Aspen's Avatar
Aspen
I would say the strut top mount as well. Also sway bar end links can make a lot of noise.
Old May 10, 2016 | 07:59 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'd second sway bar end links. If those are the slight bit loose, they can clunk. Also, maybe check the condition of your sway bar bushings as well. Definitely check over all the suspension components and make sure nothing else is loose.
888.280.7799 | 6am - 5pm PST
quickcoop
Dec 4, 2020 09:05 AM
BucksCountyR57
Mar 1, 2018 07:21 AM
padman12
Apr 28, 2016 09:15 AM
KinetechMW
Mar 19, 2016 05:52 PM
Lopez421
Mar 15, 2016 09:30 AM
