How to turn off tire pressure warning light?
Old May 8, 2016 | 04:07 PM
KevinR's Avatar
KevinR
My tire pressure warning light came on a couple of weeks ago. I was due for a tire rotation, so I just left it alone until then (2 days). Long story short: I ended up buying a set of four new tires. But the light is still on.
Everything I have found about resetting it starts with "hold the button down until the light turns on..." Well my light is on before I even push the button. I have tried the reset process at least a dozen times since the new tires were installed with no luck.
Got any suggestions?
Old May 9, 2016 | 12:44 PM
Check to make sure the button is working and connected.
https://www.northamericanmotoring.co...-wiring-2.html
Old May 9, 2016 | 01:33 PM
Capt_bj's Avatar
Capt_bj
you might have a bad wheel speed sensor ... this usually causes more lights to come on but it could be worth checking out . .
Old May 9, 2016 | 08:25 PM
KevinR's Avatar
KevinR
Thanks for both suggestions. I have some free time tomorrow so I will check those out.
Old May 11, 2016 | 06:42 AM
jamez's Avatar
jamez
I've also found that the button itself can become "sticky" and be stuck in the down position.
Popping it out of the console holder and twisting or flexing the actual button container may wiggle it and release it.
quickcoop
Sep 21, 2018 03:40 PM
Old Lotus Guy
Apr 7, 2016 04:36 PM
AlphaQuad
Mar 29, 2016 07:07 PM
afadeev
Mar 27, 2016 10:14 AM
