Backseat passenger side will not go down.
Old Mar 6, 2016 | 09:49 AM
808R53's Avatar
808R53
Has anyone ever have this problem..... both levers feels the same when pulling it up yet the driver side seat will not go down. Is there a way I can get to the lever (latch) so I can unhook it? Your help would be greatly appreciated. Aloha
Old Mar 6, 2016 | 12:23 PM
Martin Brenneke's Avatar
Martin Brenneke
looked in The Bentley manual page 520-6. There is a Bowden cable that goes to the backrest lock that you lift up. It does not show how to take seat apart but you may be able to take some screws off the backrest lock and take the lock out and see if other screws are holding backrest trim in place. good luck.
Old Mar 6, 2016 | 02:07 PM
808R53's Avatar
808R53
Thanks for the reply Martin.
Old Mar 8, 2016 | 06:49 AM
More info here:
https://www.northamericanmotoring.co...-position.html
Old Mar 8, 2016 | 09:35 AM
Martin Brenneke
Ecs tuning. I believe he is talking about the rear seat and not the front seat. If you have some info on how to fix Back passenger seat not goin forward when you lift the little lever from the boot I think he would appreciate it.
Old Mar 8, 2016 | 10:10 AM
Thanks,. thought he meant the back section of the front seat.
Like this ?
https://www.northamericanmotoring.co...le-broken.html
Here is the diagram, you have to pull up on that rear handle #10 all the way and push forward, isf the cable snapped or is undone, you will have to remove #2
Apr 11, 2017 05:45 AM
redline_rally
Classic Mini Talk
Apr 5, 2016 05:15 PM
TxMINIMama
Mar 7, 2016 09:15 AM
JaysinStrife
Mar 2, 2016 11:21 AM
mbu
Mar 1, 2016 04:09 PM
