having engine trouble (new to site)
Old Feb 28, 2016 | 04:44 PM
artchick's Avatar
artchick
Hi fellow mini owners,
I have a 09 mini cooper standard trans. not an s. a couple months ago i was experiencing what I thought was issues with my spark plugs. when in a low rpm-2000 or lower, my car would buck/ shake. I replaced my spark plugs, the problem went away for about a month. but now its back worse than ever, and my engine light randomly comes on and off. any ideas? thanks in advance.
Old Feb 28, 2016 | 05:53 PM
AZdsrt's Avatar
AZdsrt
Not much to go on. Get the code read and post it back here..
Old Apr 3, 2016 | 09:52 AM
artchick's Avatar
artchick
I got the code its p0301 cyl 1 misfire.
Old Apr 3, 2016 | 10:04 AM
AZdsrt's Avatar
AZdsrt
Probably a bad coil. Swap cyl 1 coil with cyl 2 and see if the code changes..
Old Apr 3, 2016 | 10:05 AM
artchick's Avatar
artchick
Ok I will, thank you so much
Old Apr 4, 2016 | 10:07 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, if you swap the coil from cylinder one and the misfire changes to the cylinder you swapped it to, that could be a good indication that new coils are in order. If not, more info here if that does not resolve your issue: http://www.obd-codes.com/p0301. Let us know what you find out! Welcome to NAM too!
Coils here if needed: http://www.pelicanparts.com/catalog/..._pg1.htm#item4
888.280.7799 | 6am - 5pm PST
engel
European MINIs
Apr 20, 2018 02:29 PM
Lucila
Feb 23, 2016 10:26 AM
Promius
Jan 28, 2016 07:51 AM
tlmease
Jan 20, 2016 02:58 PM
Doug W
Michigan MINI Motor Club
Jan 18, 2016 01:05 PM
