Could this be a bad thermostat housing?
Old Feb 23, 2016 | 04:38 AM
thinkinmini's Avatar
thinkinmini
So my 07 MCS seems to be losing a lot of coolant, topped off the tank yesterday, then a 40 mile roundtrip to work and back drained it to below the min line. There's a small puddle underneath the car, right near the catalytic converter (2nd one I guess, not the one on the downpipe), and theres also a lot of coolant splashed along the subframe where the powersteering pump and rack are mounted. There's also a tiny bit of coolant pooled on top the transmission, right near where those cable linkages are snapped into it ( I think they're shift cables maybe?). Does this sound like a classic case of thermostat housing failure? I've yet to get any error codes, but I'm going to scan with my Bluetooth obdII scanner tonight just to check any logged faults. What thermostat housing do you guys recommend, that's cheaper than the "genuine" mini brand?
Old Feb 23, 2016 | 07:00 AM
Yes, its will gush down that back if its leaks too much , also the water pipe can crack also,
Pools on the transmission., did this same thing on my 2007 MCS.
Get the genuine one or the Bremmen version are good. Just what ever is in stock , these sell out fast on our site. 11537534521 KT
https://www.northamericanmotoring.co...8-no-heat.html
Old Feb 23, 2016 | 11:20 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Definitely sounds like a thermostat. Typically, they start with a hairline crack which is very hard to see. Has yours ever been replaced and how many miles are on it currently? Genuine is what I'd recommend going with personally.
Genuine http://www.pelicanparts.com/cgi-bin/...-7-534-521-INT
Aftermarket options http://www.pelicanparts.com/catalog/..._pg1.htm#item4
Have you done the water pump yet? If you're wanting to tackle all of your cooling system for preventative measures you could get our water pump super kits HERE. The kits include about everything you'll need to do the cooling system job. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Feb 23, 2016 | 02:40 PM
Systemlord's Avatar
Systemlord
That's exactly where my coolant pooled up when my thermostat started leaking, on top of the transmission on drivers side. That's the case with everyone.
Old Feb 23, 2016 | 03:00 PM
Yep, had it happen on my 2007 , hence. Started talking about this back in 2013.
Old Feb 27, 2016 | 08:57 PM
sirr6's Avatar
sirr6
Just happened to me. Ecs and pelican both told me it was the thermostat, took it mini and it was. Do t take it to mini. They charged me around 800.
Old Feb 29, 2016 | 04:54 AM
thinkinmini
Yeah I definitely would NOT go to the dealership. Though I do need to have my hpfp replaced by them soon which is still under warranty til 120k. And I certainly don't have the money to replace all the cooling system components, but I will be ordering the thermostat/housing sometime this week.
Old Feb 29, 2016 | 05:11 AM
Originally Posted by sirr6
Just happened to me. Ecs told me it was the thermostat, took it mini and it was. Do t take it to mini. They charged me around 800.
Glad it was fixed, but yea you can save allot by flowing the DIY's I linked and getting the part from US. I believe I was the first to mention, years ago, to check the transmission top structure for pooling of coolant as this happened to my 2007 MCS back in the day.
Old Mar 1, 2016 | 07:27 AM
Club77's Avatar
Club77
Any idea what is this fault code? Which is the damage part?
Old Mar 1, 2016 | 07:36 AM
PelicanParts.com
Vendor
Originally Posted by Club77
Attachment 121733
You need to get a reader that can read MINI fault codes. What symptoms are you having? Just a CEL triggered?
Old Mar 1, 2016 | 08:13 AM
Attachment 121733
Thats a stored code fault by the looks , could be a wire break or mis-connection at the thermostat sensor. I would get a better scanner to read more into it.
Have you inspected all the electrical connections at the thermostat housing
Old Mar 1, 2016 | 04:21 PM
Club77's Avatar
Club77
I will send to workshop to ask them check on the electrical parts. Thanks for the adverse.
Old Mar 1, 2016 | 05:11 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
On National Back Order
The 521 Thermostats are on national back order still. However, some dealers have them in stock but limited supply and like a back ordered part usually earmarked for work done in/at the shop.
To my knowledge, there is no aftermarket version but some vendors have inventory of this OEM part.
Old Mar 2, 2016 | 05:17 AM
You are welcome Club77
We have an aftermarket version Bremmen and in stock because of the supply issue. Same newer design as Genuine MINI and we warranty it for a year, unlimited miles. If you ever have a issue we are here to help. Genuine one has come in a couple at a time. At this time its looks like they are on BO again.
Linked above and here for other alternatives.
Old Mar 5, 2016 | 09:23 PM
vballcoach's Avatar
vballcoach
I just changed mine last Sunday. It isn't hard at all. I did use the Bremmen model I purchased from Mike at ECS. When you do tackle it, take pics with your phone, access realoem.com for hose placement and orientations, double and triple check your harness plugs to be sure they are plugged in and try not to get frustrated with the clip that holds the water pipe - that was the hardest part of the replacement.
I didn't have the plug on the forward camshaft sensor plugged in all the way and after starting it threw multiple codes. I also had the heater core hoses transposed as both hoses are the same size. And finally my overflow bottle/refill cap failed and the bottle would fill all the way to the top and leak out the cap.
Mike @ ECS was a great help. New cap, corrected the hoses, attached cam sensor plug and used code reader to clear codes. Everything working great now and happy again.
Old Mar 7, 2016 | 05:14 AM
Awesome, glad that was it.
Old Apr 5, 2016 | 08:23 AM
thinkinmini
Changed the housing out this weekend, not a hard job at all. Took about 4 hours with numerous breaks.
Old Apr 6, 2016 | 08:07 AM
Congrats on the fix, yea it can take some time. just watch your fingers on those sharp plastic pieces. Mechanical gloves help.
May 9, 2017 12:35 PM
cdavidell
Jan 21, 2016 01:49 AM
cdavidell
Jan 20, 2016 01:50 PM
JPP
Jan 18, 2016 11:50 AM
Jan 18, 2016 10:38 AM
