PCV valve OK, breather hose OK...now what?
Old Aug 20, 2004 | 03:12 PM
MINI-stir's Avatar
MINI-stir
I was getting the moaning/whining noise from the supercharger area on deceleration, and upon checking the forums saw that a squishy PCV hose might be the cause of the problem. Sure enough, my PCV hose was oil-soaked, and I had it replaced at the dealer.
However, 1 day later, it is 94 degrees (F) outside, I have the aircon on and once again I get the moaning on deceleration. It is not as dramatic nor as incessant as it once was, but it is definitely still there. The breather hose seems securely attached, and is definitely much firmer than the old one. I checked my PCV valve-- it rattled, which (according to the forums) means it's OK too.
In motoring about, I notice that the noise seems to show up more often after "spirited" driving
So, any ideas on why I still get the moaning noise on deceleration?
Any help would be appreciated.
Old Aug 20, 2004 | 03:20 PM
TwOMINIs's Avatar
TwOMINIs
Moaning after spirited driving.....sure it isn't the "afterglow"? Sorry, couldn't resist...someone on here will have some better suggestions for you.
Old Aug 20, 2004 | 04:18 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The a/c will create a droning noise in hot weather occasionally. If you hear it again while driving, switch off the a/c. If you no longer hear it, it was the 'normal' sound of the a/c compressor.
Old Aug 21, 2004 | 07:40 AM
MINI-stir's Avatar
MINI-stir
Thanks, I'll give this a try once it gets hot again. As long as it's "normal" I won't worry about it.
Old Aug 21, 2004 | 09:48 AM
greatgro's Avatar
greatgro
Yeah...what GreatBear said. That's probably it.
YoloSapien
Sep 25, 2015 07:12 AM
R3411y
Sep 11, 2015 03:38 PM
Sep 11, 2015 11:09 AM
kjd186
Sep 9, 2015 10:02 AM
ShadyCoop
Sep 8, 2015 04:50 PM
